ᐅ Are there any risks associated with using IKEA Hemnes furniture for heavy loads?
Created on: 24 Sep 2023 10:23
Plotar
Plotar
24 Sep 2023 10:23
Hello everyone, I recently started looking at the Hemnes series furniture from IKEA, especially dressers and cabinets, because I want to store some heavier items in them – for example, toolboxes, thick books, and sometimes boxes with electronic devices. My question is: Are there any risks when using IKEA Hemnes for heavy loads?
I have already seen in the product descriptions that there is a recommended maximum load per shelf, but I would like to hear from your experience whether the build quality and construction are really as sturdy as they seem. Could the drawers or the frame be damaged or start to bend over time?
I would also be interested in advice on whether it is better to anchor the furniture to the wall, or if that is not really necessary. I just want to avoid doing something wrong and having something break sooner than expected. Thanks for your insights.
Deandre
24 Sep 2023 10:47
Hello Plotar, that is a very important and justified question.
In general, IKEA Hemnes furniture is made from solid pine, which provides a solid foundation at this price point. The recommended maximum load is usually around 15 kg per shelf (33 lbs). If you store heavy items—such as toolboxes or books—you should avoid concentrating the weight on just a few compartments or drawers.
Wall mounting is always advisable, especially if the furniture piece is tall and heavily loaded, as this improves stability and prevents wobbling or tipping over.
Regarding the drawers: The metal runners in Hemnes are typically designed for lighter loads, such as clothing or stationery, rather than very heavy items. Putting heavy loads in drawers over time can cause wear or deformation.
My advice: distribute the weight evenly, secure the furniture to the wall, and load drawers moderately.
kaubi
24 Sep 2023 11:22
Regarding stability and risks when using IKEA Hemnes for heavy loads, there are several technical aspects to consider.
- Material: Hemnes is mainly made from solid pine, which is generally sturdy but can exhibit natural variations in wood strength.
- Load capacity of shelves: Solid wood shelves that are milled are more stable than particleboard shelves, but manufacturers still recommend a maximum load of about 15-20 kg (33-44 lbs) to prevent long-term bending or warping of the wood.
- Structural connections: The connection between the side panels and the back panel in Hemnes is often done with tongue and groove joints plus screws. Careful assembly is important, especially under heavy loads, because poor screwing can cause the structure to deform.
- Drawer runners: The common metal slides are load-bearing but have a maximum capacity, usually less than that of the shelves. Overloading can lead to bent rails or jammed drawers.
- Wall anchoring: Essential. Particularly for taller furniture and heavy loads, it prevents tipping.
I’m curious: What specific loads do you plan to store? Should the loads be movable (i.e., in drawers) or mainly static on the shelves? Do you have the option to reinforce individual compartments with additional supports?
Plotar
24 Sep 2023 11:48
kaubi schrieb:
I’m curious: What exact loads do you want to store? Should the loads be movable (like in drawers) or mainly static on shelves? Do you possibly have the option to reinforce individual compartments with additional supports?
Thank you for your detailed reply, kaubi! To answer your questions: I primarily plan to load some shelves with heavier items – for example, toolboxes and old technical books, which are heavy and weigh quite a few kilograms. I mainly want to use drawers for lighter items, but I have also considered whether heavier things could be stored there as well. So far, I haven’t planned any additional supports, but if you advise against it, I should probably avoid them.
I’m especially interested in whether the shelf material will eventually reach its load limits with heavier weights and how this would become noticeable (warping, cracks?). I have heard that this is often an issue with more affordable solid wood furniture.
It would be great if you could also provide advice regarding the expected lifespan under these conditions.
narDietmar
24 Sep 2023 12:12
The issue with furniture like Hemnes is often the continuous load over time rather than occasional overloads.
- Shelves can bend over time, especially pine wood, which tends to swell or warp under high loads and humidity.
- Cracks usually occur due to manufacturing defects or improper assembly.
- Proper installation and, above all, securing the furniture to the wall are crucial to keep it stable and strong.
If you plan to store heavy items for extended periods, I recommend:
- Distributing the weight evenly.
- Avoid stacking loads unevenly in drawers.
- Ensuring screws and wood joints are tight and clean to prevent material fatigue.
The lifespan of such furniture can be several years to decades if the load is moderate and evenly distributed.
dijan
24 Sep 2023 13:34
Plotar schrieb:
I’m mainly interested in whether the material of the shelves eventually reaches its load limits under higher weights, and how that becomes noticeable (warping, cracks?).
Hey, sure, the material definitely reacts to that! 😅 When the loads are too high or weights remain “hanging” in one spot for a long time, you’ll start to see slight sagging or warping of the shelves. This usually becomes apparent when you remove items and the surface no longer feels flat or the shelves show visible bending — sometimes even small hairline cracks.
I own a similar Hemnes cabinet myself and occasionally store heavy things in it. I always make sure not to place heavy boxes on just one spot but to distribute the weight as evenly as possible over a larger area. It’s important to remember that especially with wooden furniture, humidity and temperature play a big role. Wood absorbs moisture and can “move” or change shape because of that.
My advice: just give it a try, but better keep a safety margin and avoid maxing out the load capacity. 😉
