ᐅ Are replacement parts available for IKEA Brimnes screws?
Created on: 20 Dec 2022 09:13
pauman
pauman
20 Dec 2022 09:13
Hello everyone, I have a specific question regarding replacement parts for IKEA furniture: Are there replacement screws available for the IKEA Brimnes wardrobe that sometimes break or get lost, which fit exactly?
It is important to me that the replacement screws match both the size and thread to ensure the stability is not compromised. Does anyone have experience with whether IKEA directly supplies matching screws or if there are recommended alternatives from third-party suppliers?
It might also be possible to use screws from a hardware store, but I’m not sure if the dimensions for Brimnes are standardized or if special types are used. Thanks for any helpful feedback!
Devin
20 Dec 2022 09:44
Unfortunately, IKEA does not offer replacement screws individually, usually only complete hardware sets.
For Brimnes, standard furniture screws are often used, which you can find at a hardware store. It’s best to measure the dimensions and choose suitable screws with a similar thread.
BOSULE
20 Dec 2022 10:31
The screws used in Brimnes are generally standard chipboard screws of specific lengths – IKEA uses only a few special screws for this model.
My advice: Measure the screw precisely (length, diameter, thread type). If replacement screws are needed, they should be made of hardened steel to ensure durability.
IKEA does not replace screws individually but recommends replacing entire fitting sets.
GiRoyce
20 Dec 2022 15:02
Hello! I understand how frustrating it is when screws get lost or break, leaving you locked out. Generally, the screws for Brimnes are fairly standard.
I have often found it helpful to contact IKEA customer service and specifically request a replacement. Sometimes they can provide replacements even if these are not officially listed in the store.
If getting to IKEA is difficult, a specialist at a hardware store can assist by suggesting or custom-making replacements based on the measured dimensions.
Additionally, some users report finding screws similar to the originals through forums or specialized screw suppliers. It is important that the material and strength match, otherwise the stability of the furniture may be compromised.
TEBILO
21 Dec 2022 07:59
Regarding the question of whether replacement parts exist for the IKEA Brimnes screws, I would like to provide a more detailed explanation.
First: The screws used in Brimnes furniture are generally not proprietary special parts. They are usually furniture connector screws with metric threads, for example M4 or M5, with a specific length (often between 30 and 50 mm (1.2 and 2 inches)) and a particular head type, often Phillips or hex (Allen).
Second: IKEA rarely sells individual screws; instead, they typically offer complete fitting kits that include a variety of screws and connectors.
Third: If a screw is lost or damaged, I recommend:
- Measuring the exact size (diameter, thread type) using a caliper or screw gauge.
- Paying attention to quality: furniture screws should be made of hardened steel to ensure sufficient stability.
- Checking at specialized hardware stores or home improvement centers, which often carry furniture or chipboard screws.
Fourth: Finding a screw head that matches the Brimnes cabinet is important, since some screw heads inside the cabinet are not accessible or visible. A Phillips head is standard; hex (Allen) is less common.
One more tip: If you still have the screw, you can have it measured at a good screw dealer. Often they even perform a test to find which screw fits best.
In conclusion: Replacement screws for Brimnes are not officially available individually from IKEA. However, suitable screws from hardware stores or home improvement centers can usually be used without problems if the dimensions are exact.
Could you perhaps provide the screw measurements? That would allow for a more targeted recommendation.
pauman
21 Dec 2022 09:22
TEBILO schrieb:
Could you please provide the dimensions of the screw? That would allow for a more targeted recommendation.
Sure! I just measured the screws that are still intact: they have a diameter of approximately 4 mm (M4), a length of 40 mm (1.6 inches), and the thread is fine pitch, similar to a standard furniture screw. The screw head is a Phillips, not a hex (Allen) drive, and the head is relatively flat so that the screw sits flush.
I found an old set of screws from Brimnes that was used inside the cabinet and wanted to base the information on that.
