ᐅ Are there any recommendations for Malm furniture for beginners?
Created on: 7 Dec 2022 08:17
piarvid
Are there any recommendations for Malm furniture for beginners who have no prior experience with assembly, especially regarding which tools are needed, which assembly steps are critical, and how to avoid common mistakes? I am considering putting together a dresser or a bed from the series and want to make sure I don’t encounter unexpected difficulties during assembly. Maybe you could also provide tips on the included materials or how to best use the instruction manual.
piarvid
7 Dec 2022 11:27
Ethan schrieb:
If you're unsure about certain steps, mark the parts with small Post-it notes or numbers.
That's a great tip, thanks! Do any of you have experience with how sturdy Malm dressers are when assembled correctly? I ask because I’m planning to use them as TV stands and place some devices on top.
liskar
7 Dec 2022 12:15
The Malm series is generally built to be stable for its intended use. The maximum load capacity is usually specified in the product description, typically around 50 kg (110 lbs) per shelf. They are suitable for TV stands, provided the size fits and the TV’s weight is not too high. Be especially careful to ensure the piece of furniture is properly secured to the wall to prevent tipping, particularly for taller models.
Paunon
7 Dec 2022 13:04
Malm dressers are sturdy enough to support TVs weighing up to approximately 40 kg (88 lbs). Do not forget to secure them to the wall. Periodically tightening the screws helps maintain their stability.
barda6
8 Dec 2022 07:02
For beginners, I recommend starting with a smaller dresser for the first piece of furniture before moving on to larger items like beds. This improves safety when handling the parts and following the instructions.
edisondan
8 Dec 2022 08:56
Additionally, it is advisable to have a second person when assembling, especially for more complex furniture. For bulky parts of the Malm beds, maintaining precise alignment significantly simplifies the assembly. It also helps to cover the assembly area beforehand with a blanket or soft material to prevent scratches.
NUPIN
8 Dec 2022 10:27
For everyone who is hesitant about assembling Malm furniture: Go for it! 🙂 The effort is definitely worth it, and in the end, you’ll be really proud to have your own piece of furniture standing there! Just take it step by step, and it will work out perfectly. And if you have any questions, don’t hesitate to ask! Speaking from experience, it’s a lot of fun!!
