ᐅ Are there protective films available that I can use for Ikea BESTA fronts?
Created on: 1 Jul 2023 08:47
melinanaHello everyone,
I have a question regarding the fronts of my Ikea Besta cabinet series. I would like to protect the surfaces from scratches, grease stains, and general wear since I really like the fronts, but I’m concerned about minor damage during everyday use in the living room or children’s room.
Are there any special protective films or alternatives that work well on the smooth, mostly lacquered wood or glass fronts of the Besta modules? It is important to me that the films can be removed without leaving residue, do not form unattractive bubbles, and do not noticeably affect the appearance.
Has anyone had experience with suitable protective films, adhesive films, or similar products that can be recommended specifically for Ikea Besta fronts?
I look forward to your tips and appreciate any concrete recommendations or advice on application and everyday suitability. Thanks in advance!
The search for suitable protective films for Ikea BESTA fronts is understandable, as the surface is often painted or melamine-coated and therefore sensitive to mechanical stress.
- PVC protective films from hardware stores are indeed a common solution, but they are not always perfectly sized for the fronts, so precise cutting is necessary.
- Special furniture films (e.g., polyurethane or transparent vinyl) offer better scratch protection and are often easier to apply without bubbles. Some manufacturers provide self-adhesive films with anti-air bubble technology that adhere well to smooth surfaces and can be removed cleanly.
- An alternative is self-adhesive anti-scratch protective films used in automotive care, as these are very durable and transparent.
Important: Consider compatibility with the surface, as some films adhere better to glass fronts than to painted wood fronts, and vice versa. Before purchasing, it is advisable to make a test cut or apply a small test area.
Hey melinana, your question makes a lot of sense!
I know this well – especially when you have kids in the house, you tend to be careful with the furniture.
I covered my BESTA fronts with a matte, transparent protective film originally designed for car windows and paint protection. The film is very thin and hardly noticeable, yet it often protects against scratches and grease stains.
A little tip: clean the surface thoroughly with a microfiber cloth first, then apply the film slowly in small sections – this helps avoid air bubbles and wrinkles. If something goes wrong, the film can be removed easily, even after being on for a long time.
It would be interesting to hear what experiences others have had!
tutan schrieb:
I covered my BESTA fronts with a matte, transparent protective film usually used for car windows and paint protection.That’s a very good idea. Automotive paint protection films are specially designed to shield surfaces from moisture, UV radiation, scratches, and minor impacts – these properties are definitely beneficial for furniture surfaces as well.
When purchasing, I recommend choosing a film with high transparency and either a matte or glossy finish, depending on which looks better with the BESTA fronts. It’s also important to select a film that can be removed cleanly without leaving residue, as some products become difficult to peel off after a long time.
For application:
- Thoroughly clean and degrease the surface
- Apply the film preferably at room temperature
- Slowly apply it while smoothing out air bubbles with a squeegee
You can use specialized cutting services to have the film trimmed to your exact measurements. This is especially useful if you want to protect multiple fronts in different sizes.
By doing this, you can significantly extend the lifespan of your fronts without compromising their design.
