ᐅ Are there any practical tips for transporting IKEA PLATSA furniture?
Created on: 4 May 2015 09:12
Koelis56Hello everyone,
I recently purchased several IKEA Platsa furniture pieces and am now facing the challenge of how to transport them most effectively. Since the PLATSA series includes relatively large modules with sometimes delicate surfaces and connection points, I would like to know if there are any practical tips for transporting these items safely and as conveniently as possible.
I am especially interested in:
- Should the furniture be disassembled on site or kept fully assembled?
- Are there specific packaging or securing materials that are particularly suitable?
- How do you manage transporting them inside a car or on a roof rack?
- What specific risks should be avoided?
I look forward to your experiences and advice!
Hey Koelis56, your topic is really relevant, especially since PLATSA furniture isn’t exactly small. 😅
From my experience: disassembling is basically a must unless you have a large truck. This way, you can pack each cabinet separately and carry them more easily. Packaging? Bubble wrap is your best friend, especially on corners and edges.
For transporting in a car, it helps to lay the panels as flat and side by side as possible—this prevents them from shifting around. I would only recommend using a roof rack with very strong tie-down straps and extra protective mats, as the surfaces are delicate!
Stay calm, with good preparation everything goes smoothly. 😉
Regarding the transportation of IKEA PLATSA furniture, I recommend the following approach:
- Fully disassemble the furniture before transport, as the modules can be very bulky and prone to damage due to their size and construction.
- Systematically label all disassembled parts to ensure a quick and efficient reassembly later.
- For packing, sturdy moving boxes in appropriate sizes work best, with additional protection from bubble wrap or soft blankets.
- When transporting in a car, lay the parts flat and as horizontally as possible to minimize stability issues and prevent deformation.
- If using a roof rack, be sure to apply a protective layer against scratches and secure the load with at least two ratchet straps.
Potential risks include damp environments, which can damage wood and particleboards, as well as point loads caused by improper securing.
I understand that this all sounds quite stressful, especially if you don’t have a professional moving company to assist you. I was also a bit worried when I transported my PLATSA parts because I was afraid of scratches and improper handling.
What helped me was staying calm and planning everything step by step. For example, I thought in advance about the best way to stack the parts in the car and packed a few old blankets to cushion everything well.
Sometimes it also helps to have someone to support you—moving is usually easier with two people.
In addition to the tips already mentioned, I would like to add the following:
- Always collect screws and small parts in labeled bags, ideally with a brief note indicating which component they belong to.
- If the PLATSA modules are equipped with flaps or shelves, these should be removed before transport to prevent breakage or warping.
- During transportation, ensure that the furniture parts cannot hit each other – any movement can damage the surface.
These measures can significantly improve the quality and safety of transport.
