ᐅ Are there any practical tips for quickly assembling Ikea PLATSA?
Created on: 12 Feb 2021 08:17
Sonbar37Hello everyone,
I am currently facing the challenge of assembling an Ikea Platsa system and want to do it as efficiently as possible without unnecessary time loss. Are there any proven and practical tips or strategies that can significantly speed up the assembly? I am especially interested in advice on the order of assembly, handling the many small parts, and possibly tricks to avoid common mistakes or confusion when sorting and building.
Thanks in advance for your experiences!
Interesting question, as people often underestimate how chaotic the assembly of Ikea systems can become. I would say that the key to quickly assembling PLATSA is not in any special assembly tricks, but in generously preparing the workspace and thoroughly sorting all parts by type and function.
That’s exactly the point: anyone who can’t organize all the screws, dowels, and panels neatly ends up wasting time searching. Also, if you’ve ever encountered a scratched or improperly stored panel, it’s worth considering whether carrying out small quality checks before starting assembly might be a good idea.
Sonbar37 schrieb:
I’m particularly interested in tips on the assembly order and how to handle all the smaller parts
Torsten4512 Feb 2021 09:29As an addition: a systematic approach is essential. My tip:
- Photograph all packaging before opening to be able to order replacement parts accurately later.
- Sort components immediately by type (panels, screws, anchors, etc.) and place small parts in labeled containers.
- Follow the assembly instructions in the exact order, as deviations can lead to errors that cause delays.
- It is also helpful to have a second pair of hands available for holding and aligning panels, especially with larger elements.
This way, you can achieve significantly faster progress.
I find the PLATSA assembly really exciting and I have a lot of fun once I understand how it works! 😊
What really helps is to unpack and sort everything first – that way, you already feel halfway done! Then, put screws and other small parts in a large bowl so they don’t roll away.
And very important: Don’t rush, take it step by step, and the work will go much more smoothly!
Good luck with the assembly!
An additional note regarding the assembly of Ikea PLATSA: The instructions should be followed precisely, especially when securing the back panels and using the connecting elements. Minor deviations can quickly lead to stability issues, which can result in complicated rework later on.
I also recommend using a cordless drill with torque control to avoid over-tightening the screws.
Being well prepared will lead to a fast, clean final result.
