ᐅ Are there options to retrofit BILLY shelves with LED lighting?
Created on: 26 Dec 2022 18:12
sepeel
Hello everyone, I am considering how to add LED lighting to IKEA Billy shelves after purchase. My idea is to enhance the appearance of the shelves with minimal effort and improve the lighting inside the compartments—perhaps using LED light strips or individual spotlights. Does anyone know of practical solutions that fit well with the shelf design and also ensure electrical safety? I would also appreciate experiences with suitable products or guides for retrofitting.
BOSULE
27 Dec 2022 11:38
sifope schrieb:
Are the LEDs permanently glued in place? How is the heat circulation handled?
I agree. Although LEDs produce little heat, caution is still necessary when attaching them to particleboard, especially for extended use. I have used flexible LED strips mounted on aluminum profiles myself. These profiles can be neatly fixed to the back or edges of shelves and help to dissipate heat more effectively.
nubar schrieb:
A good alternative to classic LED strips are slim battery-powered LED lights with dimming functions
That also sounds reasonable, but it works better for smaller shelves. If you want continuous lighting, fixed LED strips are often the better choice.
gekira
28 Dec 2022 08:10
In practice, the BILLY shelf can be upgraded with LED lighting. The choice of light type is important: flexible 12V DC LED strips are technically suitable because they operate at low voltage and generate little heat. It is recommended to choose LED strips with an adequate IP rating for indoor use, ideally with a self-adhesive backing. A certified power supply, often 12V DC, is necessary for safe operation. A simple installation involves mounting the strips under the shelves, with cables best routed along the back panel of the shelf or beneath certain moldings. Optional accessories include motion sensors, dimmers, and color temperature controls.
At the same time, it is important not to overlook the stability of the shelves, as additional weight and heat can affect the structure in the long term. In summary: yes, there are technically feasible and practical retrofit solutions, but careful planning concerning electrical safety, cable management, and fastening is essential for consistently satisfactory results.
tyson51
28 Dec 2022 12:59
Exactly, and I would like to add: When selecting, pay attention to the light color – warm white often creates a cozier atmosphere in living spaces, while neutral white tends to be more functional. It is also advisable to choose LEDs with a high color rendering index (CRI > 80) to make colors on shelves appear natural.
For installation, I have had good experiences with small clips that can be screwed into the back panel of the shelves to neatly secure cables and strips. For power supply, plug-in power adapters are ideal; they are safe and easy to replace. If unsure about electrical components, professional advice is recommended.
