ᐅ Are there more robust versions of BILLY shelves designed for heavy items?
Created on: 19 May 2023 10:27
EdmondparE
Edmondpar19 May 2023 10:27Hello everyone,
I have a question that might be relevant for some here: Are there stronger versions of BILLY shelves that are specifically designed to safely hold significantly heavier items than the usual books? I don’t only mean the standard shelves, but possibly reinforcements, special materials, or alternative constructions that noticeably increase the load capacity.
I plan to store heavy binders and technical equipment and want to avoid the shelf sagging or becoming unstable over time. Does anyone have experience with modified BILLY shelves or know of recommended reinforcements that can be implemented without much effort?
It is also important to me whether these sturdier versions are still relatively easy to assemble by yourself and don’t require a professional tradesperson right away.
Thanks for your tips!
Edmondpar schrieb:
Are there more robust versions of BILLY shelves specifically designed to safely hold significantly heavier items than the usual books?The standard BILLY shelves have a maximum load capacity of about 30 kg (66 lbs) per shelf board, depending on the width and material thickness. If you want to store heavier loads, you basically have two options:
1. Reinforce the shelves with additional metal brackets under the boards or extra support braces on the back panel. This significantly increases the load capacity.
2. Replace the shelf boards with stronger materials, such as plywood panels, which are less prone to bending.
Additionally, shallower shelf depths are generally better for heavy loads, as larger shelf surfaces tend to bend more. Wall mounting remains essential.
DIY reinforcements are quite doable, but it is important to plan the construction to be stable and safe. A professional furniture maker could also produce alternatives that look similar but are much stronger.
bupar schrieb:
Reinforcement with additional metal brackets under the shelves or extra support struts on the back panel.That sums it up very well. Additionally, I recommend attaching the metal brackets directly to the shelf and on the inside edges of the shelving unit. This helps distribute the load more evenly.
A thicker back panel made of particleboard or even solid wood also provides greater stability against lateral wobbling.
Important: The wall mounting should be done with appropriate anchors and screws, especially if the load increases significantly.
An alternative is heavy-duty shelving units, which may look different from BILLY but can support much more weight. However, if aesthetics are a priority, they are less suitable.
anken schrieb:
A thicker particleboard or even solid wood back panel for greater stability against sideways wobblingExactly, and you can make the BILLY shelves really sturdy with a few clever tricks! 🙂
I reinforced my shelves with a plywood board attached from the inside – it holds up really well and even looks neat.
And if you add metal brackets under the shelves, it’s better to use slightly larger ones for thicker boards instead of the smallest size.
Of course, it’s still a DIY project, but with some basic craftsmanship skills, you can easily manage it without needing a professional.
Good luck with your project, you’ll do great! ;-)
