ᐅ Are there moisture absorbers suitable for use with Kallax shelves in a basement?
Created on: 5 Sep 2020 13:27
dutuniHello everyone,
I have a specific concern and hope to get some helpful answers here in the forum. In my basement, I use a Kallax shelving system to store various items—mainly boxes, books, and electronic accessories. Unfortunately, I recently noticed that due to the relatively high humidity in the basement, some condensation and moisture appear on the shelves, which is obviously not ideal for sensitive items.
Therefore, I am specifically looking for moisture absorbers that can be well integrated into the Kallax shelves and effectively reduce humidity without needing frequent replacement or releasing harmful fumes. It is important to me that these products are suitable for long-term use in the basement and do not contain unnecessary chemicals.
Does anyone know if there are moisture absorbers specifically designed for Kallax or similar open shelving systems? Are there any useful tips on product selection or additional measures to consider when storing items in the basement?
Thanks for reading, and I look forward to your expertise!
dutuni schrieb:
I am specifically looking for moisture absorbers that can be easily integrated into Kallax shelvesThere are no moisture absorbers specifically designed for open shelving systems like Kallax, but common silica gel packets or granulate containers work well. Products with a high adsorption capacity, such as those based on calcium chloride, are recommended; these need to be regularly checked and replaced or regenerated once saturated.
It is important to ensure that the absorbers are suitable for residential and basement environments—that is, non-toxic and odorless. Additionally, dehumidifier devices can be used as a complementary option for targeted moisture control.
For use, it is advisable to place absorbers in easily accessible spots within the shelves so that moisture is absorbed quickly without coming into direct contact with stored items. Improving ventilation and, if necessary, insulating the basement are also recommended to reduce moisture issues in the long term.
dutuni schrieb:
Does anyone know if there are moisture absorbers specifically designed for Kallax or similar open shelving systems?To answer your question precisely: There are no moisture absorbers specifically designed for Kallax, but several products can work well in open shelves.
I recommend products containing calcium chloride, as they are more effective than conventional silica gel packets; however, calcium chloride requires a drip tray or collection bag because it turns into liquid. This means that with open shelves, it can create quite a mess quickly if no suitable container is used. Humidistat-controlled electric dehumidifiers are a more professional option here because they continuously remove moisture from the air, maintain stable humidity levels, and do not leave any liquid behind.
If you want to use absorbers specifically, I suggest placing them on the back panel or in the upper corners of the Kallax to maximize moisture absorption. Regularly ventilating the basement and using hygroscopic building materials (wood, brick) can also help bind moist air.
What exactly are the conditions in your basement? Are there moisture sources such as groundwater seepage, poor drainage, or inadequate ventilation? These factors can influence the choice of measures.
TEBILO schrieb:
Calcium chloride requires a catch tray or bag because it liquefiesThis is really important to know! Just imagine you want to absorb moisture, and suddenly there’s a puddle in your Kallax shelf – that would be counterproductive! 😉
I have a simple but effective system myself: I put small silica gel packets into breathable containers and spread them loosely across the shelf compartments. This absorbs moisture without any leakage, and you can often see from the indicator strips when it’s time to replace them.
KLONA schrieb:
Improving ventilation and, if necessary, insulating the basement is also recommendedExactly, even if it’s common sense: a well-ventilated basement controls moisture much better. Small measures like occasionally opening windows or using fans can work wonders.
So, moisture absorbers are great, but the overall moisture control strategy for the basement makes the difference. 🙂 Good luck!
