ᐅ Are there any modifications available for Ikea Platsa to adapt it to sloped ceilings?
Created on: 15 Jan 2021 08:17
Tilman61Are there modifications for Ikea Platsa to adapt it to sloped ceilings?
I am planning to use the Platsa system in my attic but have concerns about how to best adjust the storage space due to the angled ceiling. Are there any proven techniques or modifications to alter or install the individual modules so that they fit neatly against the sloped ceiling? I am especially interested in whether there are official or unofficial adaptation options, such as special attachments, shortened parts, or installation methods. If anyone has experience or good suggestions, I would be very grateful. It is also important to me that the stability is maintained and the appearance does not suffer too much.
In short and precise terms: Ikea Platsa is modular but not specifically designed for sloped ceilings.
- There are no official modifications from Ikea, especially no modules made for sloped ceilings.
- Many users cut or modify individual parts themselves, such as back panels or shelves.
- Stability is maintained if the construction is reinforced at critical points, for example with extra screws or brackets.
- Alternatively, some use angled cuts or build knee wall elements in front of the Platsa units.
Conclusion: Custom adjustments are necessary; Ikea does not offer a standard solution.
I’ll go into detail because adapting to sloped ceilings involves several technical aspects.
1. Measuring: Accurately measuring the slope is essential. Check the depth and height at every point.
2. Cutting: Many users cut the side panels of Platsa at an angle to fit the slope. It’s important to use a finer saw blade to prevent the edges from fraying.
3. Note: Platsa is made of particleboard with edge banding, which can be damaged easily when cutting. Afterwards, seal the edges with edge protectors or color-matched tape.
4. Installation: To ensure stability, the modules are often additionally anchored to the slope or screwed together.
5. Appearance: Many use cover strips or applied moldings to neatly conceal the transitions.
One more question: How steep is the slope exactly? At what height does the slope start in the room?
Domau0 schrieb:
One more question: How steep is the roof slope exactly? At what height does the slope start inside the room?Thank you for the detailed information. The slope begins at 1.80 meters (5 feet 11 inches) height and has an angle of about 38 degrees. This means I will probably have to use the Platsa system with either a reduced depth or angled side panels. The total ceiling height of the room is 2.50 meters (8 feet 2 inches).
Would it be better to cut the side panels at an angle or simply reduce the depth of the modules? I ask because I want to wait and see if this affects stability.
Tilman61 schrieb:
The slope starts at a height of 1.80 meters (5 feet 11 inches) and has an angle of about 38 degrees.With the given angle and height, a slanted cut of the side walls is often more practical than reducing the depth, as this allows the modules to retain their full depth and preserves storage space.
Procedure:
- Mark and cut the side walls as described in the previous post.
- Create angle templates from cardboard beforehand to check fit accuracy.
- Ensure stability by adding extra connections between the modules and wall fixings.
Avoid shortening the entire depth, as this unnecessarily reduces storage space.
If you need help with the adjustments, I can offer a few simple tips:
- Use a spirit level and angle templates to transfer the slope precisely.
- If you have little experience with cutting, it’s better to have someone skilled in woodworking do the job.
- Afterwards, cover the edge glue with special edge banding or edge protectors.
- For stability, corner braces can help; you can mount them on the side wall and the wall.
- Keep moisture protection in mind, especially if there is a roof slope above.
I followed this exact approach with Platsa in my attic, and it looks neat and is stable as well.
