ᐅ Are there any mechanical issues with the drawers of the IKEA Brimnes series?
Created on: 4 Jul 2018 19:37
mimisan
mimisan
4 Jul 2018 19:37
Hello everyone, I bought the IKEA Brimnes dresser model with three drawers last week and I’m not sure if this model has any mechanical issues with the drawers. Specifically, I am concerned about the stability and durability of the drawer slides as well as the opening and closing functionality. Sometimes I notice that the drawers stick slightly or are not as smooth to operate as I’m used to with other furniture. The slides seem to be made of metal, but something feels a bit loose. I’m interested to know: Are there common reports of mechanical weaknesses with the drawers of the IKEA Brimnes, and if so, what causes are known? Have other users had similar experiences or even solutions? I want to be sure if this is a known problem or if I might have assembled it incorrectly. Thanks in advance for any advice!
Johnathon
4 Jul 2018 20:11
mimisan schrieb:
Sometimes I notice that the drawers stick slightly or don’t glide as smoothly as I’m used to with other furniture.
This issue occurs quite often with Brimnes dressers. The drawer slides are basically simple metal runners without advanced ball bearing technology, which can lead to somewhat sticky movement with frequent use or even small manufacturing tolerances.
From a technical standpoint, it is important that the guide rails are mounted exactly parallel and precisely aligned. Even minor deviations in angle or slight dirt can disrupt the sliding motion. Another factor is the material: IKEA often uses thinner metal with lower tolerances here, which can promote warping over time.
Have you checked whether the rails are completely free of dust and debris? Are all screws in the drawers and the cabinet securely tightened? After several days of use, you can often observe whether the drawer settles in or if the problems worsen.
I would also recommend fully removing and reinserting the drawer, as it can sometimes get caught in the groove. Also, have you exceeded the maximum load capacity?
One more question: Do you have this problem with only one drawer or with all three? And are they loaded with similar weights?
Sagegi
4 Jul 2018 20:53
The mechanical slides used in IKEA Brimnes drawers are generally designed to handle moderate loads typical for residential use. The guide rails consist of simple steel profiles combined with plastic gliders. Advantages include low cost and low maintenance.
Disadvantages are:
- less smooth operation compared to ball bearing slides
- potential sticking issues if misaligned
- over time, plastic wear particles may cause minor contamination
Mechanical problems can result from incorrect installation, excessive loading, or improper fitting.
Conclusion: These are not high-performance slides but an affordable solution with expected limitations. As long as they are not overloaded or installed crookedly, significant problems are unlikely.
Luchen
4 Jul 2018 21:07
I have several Brimnes dressers in use. No issues with the drawer mechanisms so far. Important: install the slides correctly and keep them clean.
If drawers stick, first check the alignment and the load.
tolokau
5 Jul 2018 07:41
For clarification: The Brimnes drawers operate on basic drawer slides, which are common in entry-level furniture. Here are some tips that might help if the drawers are sticking:
1. Check the slide tracks:
- Inspect the rails for any debris, hair, or dust buildup. These can significantly affect how smoothly the drawer moves.
2. Alignment:
- Fully open the drawer and check if it sits straight in the track. If the metal runners are not exactly parallel, sticking can occur.
3. Inspect screws:
- Sometimes the screws holding the slides in place are not tightened properly, which can lead to misalignment or tension.
4. Observe load capacity:
- Do not exceed the recommended maximum load (usually around 15 kg (33 lbs) per drawer).
Common installation mistakes include twisting the drawer or inserting it at the wrong angle. If all of these points are correct, you can carefully apply a small amount of silicone spray to the rails to improve sliding performance. However, do not use too much, as it can attract dirt.
In summary: These simple mechanical slides are not necessarily designed for heavy-duty or constant use under maximum load, but when properly installed and maintained, they typically last long enough.
RIDAN
5 Jul 2018 08:03
At first, the drawers of the Brimnes were a bit stiff. Simply removing and reinstalling them solved the problem. Make sure to tighten the screws properly and do not load them heavier than recommended.
