ᐅ Are there lighting solutions for Ikea PLATSA that are easy to install by yourself?
Created on: 18 Feb 2021 09:23
gufusau
Are there lighting solutions for Ikea PLATSA that are easy to install by yourself? I’m looking for options that not only match the PLATSA system aesthetically but are also simple to set up. It’s important to me that no advanced electrical knowledge is required, ideally plug-and-play solutions or models with straightforward assembly. Maybe someone knows good alternatives or has experience with specific products or DIY setups that can be easily integrated into the PLATSA shelving unit?
TARAON schrieb:
Even the biggest technology skeptic becomes a lighting designer.That sounds very promising. I’m curious if anyone has experience with Ikea’s own lighting solutions for Platsa, possibly using the TRÅDFRI system? I’ve read that it’s supposed to be compatible and controllable via an app, but I’m not sure how straightforward the installation really is.
gufusau schrieb:
I’m curious if anyone has experience with Ikea’s own lighting solutions for PLATSA, possibly with the TRÅDFRI system?I installed the TRÅDFRI system myself, and it’s really straightforward. No prior knowledge is needed, as the modules are designed for furniture and come with detailed instructions. The app setup is intuitive as well, allowing you to dim the lights or set schedules. A key advantage is the integration with smart home systems, if that’s important to you.
JAMESONB4120 Feb 2021 09:05Julien schrieb:
The app setup is also straightforward, and you can adjust dimming or set schedules.Exactly, with TRÅDFRI the installation is just as simple as with other plug-and-play lighting systems. Plug in, stick in place, done.
