ᐅ Are there LED lighting solutions specifically designed for Ikea Pax interiors?
Created on: 31 Oct 2016 14:23
naran41Hello everyone,
I have a detailed question regarding interior lighting for Ikea Pax wardrobes: Are there LED lights specifically designed for the interiors of Ikea Pax systems? I am particularly interested in solutions tailored to the internal dimensions and mounting options of the Pax wardrobes. I’m looking for something that’s easy to install, ideally with an integrated power supply or battery, and provides sufficient brightness to clearly illuminate even the back corners.
Has anyone had experience with this or can recommend suitable products that are precisely designed for Ikea Pax interiors?
Thanks in advance for your support!
Hello naran41,
regarding your question: Yes, there are indeed LED lighting solutions specifically designed for Ikea Pax wardrobes.
Here is an overview of how they differ:
- Conventional LED strips are often too long or difficult to position without modification.
- Special Pax LED lights are usually slimmer and come with brackets that can be attached to the inside of the wardrobe.
- Some models include magnetic mounts or adhesive strips, which work well on smooth surfaces.
- Battery-powered options are convenient when there is no power outlet nearby.
An important tip: When purchasing, pay attention to the dimensions and mounting method to ensure they fit easily. The color temperature is also important—daylight-white LEDs are recommended for wardrobe lighting as they display clothing colors more naturally.
If you like, I can provide some specific product recommendations and installation tips.
I would like to add: For a clean and long-lasting solution, I recommend LED lights with a 12V power supply, as they usually offer better brightness and lifespan.
Many of the LED lighting options specifically designed for Pax wardrobes are either from third-party suppliers or Ikea itself, such as the "Omlopp" system, which was developed specifically for the interior sides of Pax wardrobes.
It is important that the transformer is neatly concealed and that the wiring is not too visible in order to avoid negatively affecting the appearance of the wardrobe.
kla65 schrieb:
I used simple LED strips from Ikea for my Pax wardrobe, which are well sized.That’s a useful tip, kla65. However, I would recommend everyone to check the exact dimensions of their Pax model before purchasing. Pax comes in different widths and depths, which can affect the choice of the right LED strip.
Additionally, a few recommendations:
- Install the LEDs preferably along the inner edge of the door or on the side panels
- You can use either bright linear LED strips or small spot LEDs
- Make sure no cables are hanging loose or visible to maintain aesthetics and avoid snagging hazards inside the wardrobe
This will enhance both the functionality and quality of the wardrobe lighting.
PRA64 schrieb:
That’s a good point, kla65. Still, I would recommend everyone to check the exact dimensions of the Pax model before purchasing.Thanks for the tip, PRA64. I have a Pax wardrobe with a width of 100cm (39 inches) and a depth of 58cm (23 inches).
I’m interested to know whether most specialized Pax LEDs can be easily installed on such large models, or if there are limitations with the bigger versions? Also, are there differences between battery-powered and mains-powered lighting solutions for wardrobes of these dimensions?
