ᐅ Are there any known weaknesses or common issues with IKEA Hemnes cabinets?
Created on: 26 Aug 2019 10:23
Neofu
Are there any known weaknesses of IKEA Hemnes cabinets?
I am planning to get a Hemnes wardrobe, and since I know that solid wood furniture is sturdy but not always perfect, I wanted to ask in advance for opinions and experiences. I am particularly interested in aspects such as the stability of the construction, possible issues with workmanship (e.g., warping due to moisture), weaknesses in the hinges or wooden parts, as well as the quality of the fittings.
I want to make sure I assemble everything correctly and am aware of potential risks early on. Are there also any care tips or common quality problems that occur more frequently with Hemnes wardrobes?
Jeanbar
27 Aug 2019 09:35
To add to the question:
It is important to know that solid wood products like the Hemnes wardrobe naturally respond to changes in temperature and humidity. This means that slight tensions and small cracks can be normal over time, but they do not necessarily indicate a serious defect.
For assembly, I can only recommend carefully following the instructions and allowing enough time for the process. Properly aligning the doors and using the included wall anchors significantly increases stability.
Additionally, it is helpful to place the wardrobe in a location with stable humidity to minimize warping.
Tarlo
27 Aug 2019 12:11
elliot schrieb:
The back panels are often made of thin MDF or hardboard, which can affect long-term stability.
This is a very important point. The back panel provides the necessary lateral stability for Hemnes cabinets. If it is not securely attached, the cabinet will become unstable quickly.
I have also noticed with several Hemnes pieces that the surfaces at the edges wear down over time, especially if the cabinet is not maintained properly.
Regularly checking the screws and occasionally tightening them is therefore advisable.
Deoren
27 Aug 2019 16:50
In short: Hemnes cabinets are sturdy, but assembly and placement are crucial. Wood expands and contracts, so secure the back panel, adjust the doors, and retighten the screws.
V
vincent46
28 Aug 2019 07:19
Gregory schrieb:
Anyone wanting to secure the cabinet against tipping should definitely use wall anchors
I can only agree with that! There was a moment with my cabinet when I hadn’t installed the wall anchors yet – the piece of furniture noticeably wobbled when moving around the room.
Since the rail was properly installed, it has been rock solid. This especially provides peace of mind with children around and helps prevent accidents.
For maintenance, I also recommend avoiding harsh cleaning products. It’s better to use a damp cloth and a mild wood care product.
