ᐅ Are there any known weaknesses or common issues with IKEA Hemnes cabinets?
Created on: 26 Aug 2019 10:23
NeofuAre there any known weaknesses of IKEA Hemnes cabinets?
I am planning to get a Hemnes wardrobe, and since I know that solid wood furniture is sturdy but not always perfect, I wanted to ask in advance for opinions and experiences. I am particularly interested in aspects such as the stability of the construction, possible issues with workmanship (e.g., warping due to moisture), weaknesses in the hinges or wooden parts, as well as the quality of the fittings.
I want to make sure I assemble everything correctly and am aware of potential risks early on. Are there also any care tips or common quality problems that occur more frequently with Hemnes wardrobes?
The Hemnes series from IKEA is generally solid, but there are some aspects that can be considered weaknesses.
- Although the construction uses solid wood, it is mostly pine, which can swell and warp under heavy load or high humidity.
- The back panels are often made of thin MDF or hardboard, which can affect long-term stability.
- Hinges often include plastic components, which may wear out over time.
- Assembly errors are frequently the main cause of wobbly cabinets, especially if the stabilizers at the back are not properly secured.
In general, careful assembly and choosing the right location (low humidity, no direct sunlight) are crucial.
In addition to elliot's comments, I would like to address the load capacity of the shelves: Users often report sagging shelves in Hemnes cabinets under heavy weight. The shelves are solid but relatively narrow, so they can bend if overloaded or if the weight is unevenly distributed.
Another weak point is the connecting fittings (metal brackets and dowels). If assembled incorrectly, these can loosen, causing instability. Screws should also be checked regularly and tightened if necessary.
Anyone wanting to make the cabinet tip-resistant should definitely use the wall mounting hardware supplied by IKEA.
V
vincent4626 Aug 2019 13:05I have had a Hemnes wardrobe for over two years and can share my experience.
Overall, I like the look and the craftsmanship, but I have actually encountered a few issues: In the summer, when it gets warm and humid, the paint layer has partially peeled off along the edges. It wasn’t serious, but definitely annoying.
Also, the hinges seem to loosen over time – the doors no longer stayed perfectly aligned and had to be readjusted. Since then, I always make sure to tighten the screws properly.
The most important thing is to assemble the wardrobe exactly according to the instructions and secure it to the wall, otherwise it becomes unstable quickly.
I love my Hemnes wardrobe, but I also want to be honest: there are some minor flaws! 😊
- The doors can be a bit tricky to adjust, but with some patience, it works out great!
- The bottom sagged slightly under heavy clothing in my experience, which I found acceptable personally, and I simply added another board for support.
- Assembly is quite an adventure – investing an extra hour never hurts.
So, if you stay flexible and use a few tricks, you’ll really enjoy this piece of furniture!
