ᐅ Are there any known weaknesses in Billy bookcases that commonly cause issues?
Created on: 28 Apr 2019 08:04
U
Usfra67
I am currently looking into IKEA Billy bookcases and wondering if there are any known weak points that commonly cause issues during use.
Specifically, I am interested in whether there are design flaws, material weaknesses, or assembly difficulties that could lead to problems in everyday use, such as instability under heavier loads or warping.
Has anyone had experience with this and can provide detailed insights on what weaknesses I should watch out for to ensure the best long-term solution? Thanks in advance!
Hi!
From my own experience, I can say that Billy shelves are quite reliable with normal use. 🙂
In my case, the loads are not extremely heavy, and I have securely fixed the shelves to the wall.
That’s true, the coating is not very durable – but considering the price, I think that’s reasonable. If you need more robustness, custom-made or heavier-duty solutions are probably better.
So: fine for simple purposes, but rather questionable for heavy or professional use.
Usfra67 schrieb:
the edges wear out quickly with frequent use
I love my Billy shelves! 😄 But the secret really lies in proper installation and maintenance!
If you securely fix them to the wall and avoid overloading, you can enjoy them for a long time. The small supports you slide under the shelves also help a lot.
Exactly, that’s what makes the difference! Good luck!
Luchen schrieb:
Always use wall anchors; this makes the shelf much more stable.
TARAON schrieb:
A common issue is that the shelves tend to sag over timeThank you all for your valuable advice! I can see that my impression was correct and that the weaknesses mainly lie in the load-bearing capacity of the shelves, the mounting, and the sensitivity of the materials used.
I will definitely take to heart the tips regarding wall mounting and reinforcement. I’ll see if I can add a few extra supports or wooden battens to improve longevity.
I will also keep an eye on the edge banding and perhaps use suitable edge protectors to reduce wear.
Thanks for the exchange and the tips! 🙂
