ᐅ Are there any known issues with transporting Ikea HEMNES furniture?
Created on: 10 Sep 2020 08:47
lauli68
lauli68
10 Sep 2020 08:47
Good morning everyone,
I am currently planning the transport of an IKEA Hemnes wardrobe and want to avoid potential issues. My specific question is: Are there any known or common problems when transporting IKEA Hemnes furniture, particularly regarding the stability of the components, the type of packaging, or handling during loading and unloading?
From experience with other furniture, I know that screws can sometimes loosen or panels can get damaged if not properly secured. Unfortunately, I haven’t been able to find reliable reports specifically about transporting Hemnes furniture, only about assembly. It would be helpful if you could share your experiences with this particular piece so I can avoid possible mistakes in advance.
Thanks in advance for your insights and tips!
GIPAPO
10 Sep 2020 09:12
When transporting HEMNES furniture, please note the following: Tighten all screws before transport. Do not stack boxes on their sides. It is best to pack individual parts well and use padding. This helps prevent damage such as scratches or warped panels.
tolokau
10 Sep 2020 10:35
To address your question specifically, lauli68: The IKEA HEMNES furniture is made from solid pine wood, which is very sturdy but also presents certain challenges during transportation.
A brief overview of what you should keep in mind:
- The relatively heavy solid wood panels can break or get damaged if stored improperly, especially corners and edges are vulnerable.
- Screws and dowels: Before transport, it is advisable to slightly loosen already assembled components to relieve tension. Fully tighten screws only after transport.
- Packaging: IKEA usually packs flat and securely, but internal edge protection is sometimes minimal. Additional padding or blankets can help here.
- Transport method: The furniture should be transported lying flat and never standing on the side or tilted.
By considering these points, you can significantly reduce the risk of transport damage to the HEMNES cabinet.
Genevieve
11 Sep 2020 12:08
GIPAPO schrieb:
It’s best to pack the individual parts well and use padding.
This advice certainly makes sense, but can we actually assume that IKEA does not provide sufficient padding in the packaging for HEMNES in regular retail?
I question this because most IKEA furniture is designed for self-assembly with simple measures in mind, but this does not necessarily apply to transport (especially independent transport). Are there reports that the packaging for HEMNES is truly inadequate, or is this more of a precautionary recommendation from experienced DIYers like GIPAPO?
I think it’s important to distinguish between actual shortcomings and precautionary tips to avoid unnecessary effort.
pikin
12 Sep 2020 16:43
tolokau schrieb:
The relatively heavy solid wood panels can break or get damaged if stored improperly, especially the corners and edges, which are sensitive.
This is an important point.
Additionally, I would like to add that with HEMNES, due to the solid wood, moisture can be particularly problematic during transport, as the panels may swell or warp if they are not properly protected.
Therefore, it is essential to cover the cabinet well and transport it in a dry vehicle.
Furthermore, unnecessary movement of the parts should be prevented, for example by sufficient cushioning and securing in the van or car.
In summary, I would say the main issue when transporting IKEA HEMNES is its sensitivity to mechanical impacts and moisture – something everyone transporting it themselves should keep in mind.
