ᐅ Are there any known issues with the electrical lighting in Pax?
Created on: 19 Jul 2017 18:37
EVERETTHello everyone, I have recently heard more often about possible issues related to the electrical lighting in Pax and would like to know: Are there any known technical difficulties or weak points with the electrical lighting in Pax modules or systems? I am especially interested in whether there are common causes of failure, for example in the wiring, the light bulbs, or the control unit, that frequently occur in Pax and should be relevant for users. If anyone can share personal experience or technical details, I would be very grateful for a detailed assessment!
Hello EVERETT,
I can explain this in a bit more detail. There are a few common issues with the electrical lighting in Pax:
- Wiring: Often, the internal wiring in DIY builds is a bit undersized. This can lead to heat-related problems and occasional contact interruptions.
- Light bulbs: Not all LEDs are compatible with the voltage converter in Pax. This can cause flickering or reduced brightness.
- Control system: The touch panel or control unit can sometimes fail or be incorrectly configured. This then affects functions like dimming or power-on delay.
My advice: Always carefully check the wiring diagrams before installation and only use components from the recommended range. This helps avoid many errors.
If you like, I can also suggest suitable alternatives or troubleshooting steps.
Great topic, EVERETT! 😊 I once had a situation where the lighting in the closet started flickering suddenly. After some research, I found that it was caused by cheap LED bulbs combined with the dimmer. Replacing them with a branded product solved almost all the problems for me! So don’t give up—most issues can be identified and fixed!
RIDAN schrieb:
Especially with self-installed connections without professional fitting, loose contacts often occur.That’s true, which is why I always recommend firmly crimping cables and checking all connections multiple times. A secure fit is crucial.
