ᐅ Are there any known issues with IKEA Besta back panels, and how can they be resolved?
Created on: 1 Apr 2017 09:27
Farreo58
Farreo58
1 Apr 2017 09:27
I recently assembled an IKEA Besta shelving unit and noticed some uncertainties regarding the back panels. Therefore, I have a question for the community: Are there any common issues with IKEA Besta back panels, such as fit, stability, or material quality? If so, how have you resolved these problems?
I am especially interested in practical tips or tricks for installing the back panel correctly without causing damage, and whether any additional measures are recommended to ensure the overall stability of the shelving unit.
Thanks in advance for your input and experiences!
Parbo
1 Apr 2017 10:15
Hello Farreo58,
Regarding your question: Yes, there are indeed some recurring issues with the IKEA Besta back panels that I know from personal experience and reports from several other users.
- Fit: The back panel is often slightly too large or too small, which can cause it not to fit perfectly into the cabinet or to be difficult to fasten properly.
- Material thickness: Since the back panels are made of particleboard or thin MDF, they tend to warp or fail to lie completely flat, especially with larger units.
- Fastening: The standard clips and screws don’t always hold firmly, particularly when the back panel is not completely flush.
Solutions:
- It’s advisable to adjust the back panel before installation (e.g., by lightly sanding or trimming) if it’s too big.
- Gluing small plywood strips between the back panel and the frame can improve stability and reduce warping.
- Additionally, using alternative screw systems or small brackets can secure the back panel more reliably.
My recommendation is to work carefully during assembly and be prepared to make modifications instead of just using all parts as they are.
I’m interested to know which specific variants or sets you are referring to, as there are some differences.
SIAURORA
1 Apr 2017 11:43
Parbo schrieb:
The back panel should be adjusted before installation (e.g., lightly sanded or trimmed) if it is too large.
That’s exactly the point I keep criticizing IKEA for: Why do they sell back panels that don’t fit precisely? To me, it’s a design and quality issue. People buy a piece of furniture expecting everything to fit together easily, only to have to start making manual adjustments themselves.
Furthermore, I wonder if the warping of the back panel is fundamentally a material problem. Thin particleboard is cheap and lightweight but simply not stable.
My impression is that if you rely on IKEA, you often have to accept half-baked solutions and get creative.
What do you think? Is this an acceptable compromise for affordable furniture, or is it a poor reflection on IKEA?
suru61
1 Apr 2017 12:58
SIAURORA schrieb:
Why do they sell back panels that don’t fit exactly?
Oh yes, you’ve touched on something here! I always find it interesting how IKEA somehow manages to package it with that typical Swedish charm – you know, furniture to build yourself with parts that fit more or less. 😄
But honestly, I think there’s also a clever reason behind it: if everything were perfectly precise, the furniture would lose that DIY appeal. Jokes aside, the back panels are flexible and sometimes make assembly easier, especially if the shelf is on an uneven floor.
With my Besta shelves, I simply used small wooden wedges to secure the back panel a bit. That worked quite well and added stability.
The important thing is not to make a big deal out of it – a bit of improvisation is just part of the IKEA experience. 😉
Farreo58
2 Apr 2017 08:37
Thanks in advance for the feedback!
@Parbo: I’m using the classic Besta units with the white laminate surface, and the backs are the standard brown particle boards.
It’s interesting that you mention the plywood strips. I was already considering fully gluing the back panel with assembly adhesive – do you have any experience with that? Or are screws really better?
@SIAURORA and @suru61: I understand your viewpoints well. IKEA produces in large quantities and aims to reduce costs, so smaller quality issues are probably expected with affordable furniture. On the other hand, I believe that for components like back panels, a basic level of accuracy and easy assembly should be guaranteed. I sometimes feel this optimization is missing.
I would like to know if anyone has used alternative back panels or managed to obtain these parts more robustly as replacements?
RUBEN54
2 Apr 2017 16:22
Here is a brief tutorial that might help with this topic:
1. Check the back panel for dimensional accuracy before installation. If it sticks anywhere, lightly sand the edges.
2. Position the back panel precisely within the frame, regardless of any tension it might have.
3. First, attach the back panel at the base of the shelf using small nails or screws, if specified.
4. If the back panel is warped, place small wooden strips against the frame to support it and prevent sagging.
5. Use small metal brackets in the corners to further increase stability.
6. To improve stability, a light adhesive can be applied to the contact surfaces, but be careful to keep the shelf removable.
Common mistake: Forcing the back panel in with excessive pressure, which often leads to cracks or deformation.
Conclusion: Minor craftsmanship adjustments significantly improve the fit of the back panel and have a positive effect on overall stability.
