ᐅ Are there any known issues with installing the back panels of Ikea Brimnes furniture?
Created on: 9 Nov 2020 19:37
sinLuisaHello everyone,
I joined this forum because I’m currently having difficulties assembling my Ikea Brimnes wardrobe, which seem to be related to the back panels. Specifically:
Are there any known issues with assembling Ikea Brimnes back panels?
I get the impression that the back panels often don’t fit properly or warp during assembly. Sometimes the pre-drilled holes don’t seem to be perfectly accurate, which makes attaching them difficult. Maybe some of you have experience with how to avoid common pitfalls or if material defects are frequent.
I’m also interested in whether there are different versions of the back panels that possibly vary in material or dimensions.
Thanks for your support!
Hello sinLuisa,
I can provide some clarity since I have assembled several Brimnes cabinets myself and often install back panels.
Issues with the Ikea Brimnes back panels do occasionally occur, mainly in these areas:
- Fit accuracy of the back panel strips: Sometimes the boards are slightly warped, or the pre-drilled holes are not exactly in the right position. This can cause screws to require adjustments when being inserted.
- Material quality: The back panels are often made of thin hardboard or particleboard, which can easily chip if screws are not handled carefully.
- Assembly instructions: Some manuals are quite schematic, making precise alignment difficult without measuring.
Tips I recommend:
- Check the back panels for warping before installation by laying them flat on a level surface.
- Use fine-thread screws and insert them slowly to avoid chipping.
- If the holes don’t quite line up, mark the correct spots manually and pre-drill with a very small drill bit.
- Use a level and align the back panel exactly on the frame before fastening everything.
If you like, I can also share some tricks for straightening the back panels afterward to relieve tension.
In general, these problems are not severe but well known. They are usually technical in nature and can be resolved with some patience and careful workmanship.
I hope this helps!
Tips I recommend:
I hope this helps!
I can understand your uncertainty. Especially with furniture that you have to assemble yourself, issues with the back panels can be really frustrating. I had a similar experience when my back panel wouldn’t lie flat, and I was worried that the cabinet might warp as a result.
What helped me was compensating for small irregularities by using some cardboard or foam tape as a spacer and carefully securing the back panel little by little. It requires patience, but it provides the reassurance that everything fits properly in the end without damaging the material.
Maybe you could try making those fine adjustments too? Taking a calm and careful approach here is definitely worthwhile.
Hello sinLuisa,
I would like to add that the Brimnes back panels often have the problem of needing reinforcement because they are quite thin and can easily bend or splinter if handled improperly.
A proven repair and precautionary approach is:
- Lay the back panels flat on an even surface and inspect them first
- Lightly sand the edges with fine sandpaper if any splintering is visible
- Carefully drill out the holes with a thin drill bit if they are not perfectly aligned
- Insert the screws with gentle pressure and at the correct angle
If you have experienced issues with warped back panels before, I recommend not rushing the assembly. Taking a little extra time to work carefully will pay off.
If you have any specific questions about the material, feel free to ask again.
