ᐅ Are there affordable edge banding options for KALLAX available at home improvement stores?
Created on: 16 Jan 2016 10:17
Miixjon
Hello everyone!
I have a fairly specific question that’s been on my mind for some time, and I’m hoping someone with relevant experience can help: Are there affordable edge bandings suitable for the IKEA KALLAX shelving unit that can be found at hardware stores?
I’m looking for a solution that is not only cost-effective but also convincing in terms of durability and ease of application. Since KALLAX has quite thin edges, it’s important to me that the edge banding isn’t too thick and adheres well to the MDF.
Maybe someone has tips on particular brands, hardware store chains, or alternative sources for so-called "edge bandings" that have already been tried and tested?
Thanks in advance for your replies!
Sinan-meo
17 Jan 2016 10:36
Regarding edge preparation:
1. Lightly sand with 180-grit sandpaper; this is enough to remove loose particles.
2. Remove dust with a dry cloth or brush.
3. If edges are painted, lightly sand to ensure the edge banding adheres properly.
Do not use moisture when cleaning, as it can reduce the adhesive strength.
klo40
17 Jan 2016 11:45
Sinan-meo schrieb:
Lightly sanding with 180-grit sandpaper is sufficient to remove loose particles.
That’s exactly how I do it as well. Additionally, I recommend cutting the edge banding about 2-3 cm (1 inch) longer than the edge before ironing it on. After bonding, carefully trim the excess with a utility knife.
For optimal results, I use a bone folder for gentle pressure after ironing. This helps prevent air bubbles and ensures clean, finished edges.
In my opinion, the project "edge banding on KALLAX" is very achievable with a bit of care and can really create an affordable, high-quality effect.
sarGabriel
17 Jan 2016 12:04
I often use simple edge banding from d-c-fix, available at hardware stores. It is cost-effective, easy to apply cleanly, and fits well with the KALLAX shelving unit. The key factors are always the right width and a steady hand when using the iron.
