ᐅ Are there IKEA Platsa wardrobe combinations that are particularly sturdy?
Created on: 14 Mar 2015 09:42
nicori
nicori
14 Mar 2015 09:42
I am thinking about getting an IKEA Platsa wardrobe but am unsure if there are certain combinations that are particularly sturdy and durable.
Specifically, I am interested in whether some of the Platsa modules or combinations are more stable than others, and if the material or assembly method affects their load-bearing capacity.
I plan to use the wardrobes not only in the bedroom but also in the hallway and possibly even as a small cloakroom, where they will be subjected to higher stress, for example, from placing bags, jackets, etc.
Does anyone have experience or recommendations on how to optimize the stability of Platsa wardrobes? Are there combinations known for better construction or reinforcements? Any advice on assembly or the materials used would also be very helpful.
Noahlu
14 Mar 2015 11:37
The question of whether there are particularly sturdy Platsa combinations is not easy to answer, as IKEA generally focuses on modular, medium-duty furniture with Platsa.
For good load-bearing capacity, the construction is especially important:
- It’s best to use the larger modules, as their base panels and side walls are more stable than those of smaller units.
- Make sure to mount the back panel correctly; it provides essential cross braces and stability.
- Attaching the cabinets to the wall, which IKEA explicitly recommends for many systems, greatly increases stability.
In terms of materials, Platsa components mostly consist of particleboard with a melamine coating; this is solid but not comparable to solid wood or plywood.
If you want a robust combination, you should:
- avoid building tall, narrow units,
- take advantage of module variety to create a broad base with multiple attachment points,
- use all the supplied connectors fully and carefully.
One more question: How tall do you want the cabinets to be? Are you using doors or open shelves? This will affect the load and stability.
Z
zartra
14 Mar 2015 13:04
The most stable Platsa combinations are those with larger base modules and a properly installed back panel. Wall anchoring is absolutely necessary.
Danabla
15 Mar 2015 08:26
Noahlu schrieb:
If you want a sturdy combination, you should:
- avoid building very tall, narrow combinations,
- use a variety of modules to create the widest possible base and multiple attachment points,
- use all supplied connectors completely and carefully.
I fully agree with that. Additionally:
- Platsa is designed for moderate loads. For very heavy use (e.g., heavy work materials or lots of clothing weight), additional reinforcements should be considered.
- Using floor pads or self-adhesive rubber pads can improve stability on uneven floors.
- Careful assembly of all brackets and connectors minimizes the risk of twisting and reduces stress on individual connection points.
If maximum durability is desired, a complete retrofit with extra screws or brackets not included in the standard delivery from IKEA might be recommended.
geneda
15 Mar 2015 10:17
Hello nicori, I completely understand your concerns, as the load-bearing capacity of Platsa is indeed an important topic.
In addition to the points already mentioned by Noahlu and Danabla, I would like to add:
- If you are using the modules with doors, make sure the hinges are properly adjusted, as incorrect alignment can cause warping.
- Stability can be improved by not only connecting the cabinets at the back panel but also using cross connectors between individual modules (sometimes available as accessories).
- It is also possible to place the Platsa units on wooden slats or feet to minimize contact with the floor and thus prevent damage from moisture.
If you like, I can also share tips on correct assembly that have proven to be very durable in my experience.
