ᐅ Are there any IKEA PLATSA options available with glass fronts?
Created on: 27 Dec 2022 10:32
Par35I am currently exploring various options to upgrade my IKEA Platsa shelving system. Specifically, I am interested in whether IKEA officially offers versions or accessories for Platsa that feature glass fronts. My idea is to enhance the simple Platsa base system with transparent or semi-transparent fronts to better showcase display areas and provide dust protection.
Does anyone here know of any glass-front options officially offered by IKEA? If so, are there differences in the types of glass (clear glass, frosted glass, etc.)? Or are such glass fronts only available through third-party sources or DIY solutions? I would greatly appreciate detailed information and any personal experiences, as the IKEA website and catalogs don’t provide much on this topic.
Directly from IKEA, PLATSA does not offer glass fronts as a standard option. There are doors and drawer fronts, but they are usually made of wood or MDF.
However, you could cut and install glass fronts yourself if you have the appropriate door frames or modify the fronts accordingly.
In detail: The PLATSA system is modular and based on units made from wood-based panels that can be combined with various doors and fronts. Officially, IKEA currently does not offer glass fronts for PLATSA, which is also due to the design – the doors are not specifically constructed for glass inserts, meaning they do not have built-in glass panels or the necessary mounting elements.
If glass fronts are desired, third-party options or DIY solutions quickly come into play: for example, acrylic (Plexiglas) or single-pane safety glass strips can be inserted into wooden frame doors using special clamping or sealing profiles. Precise measurements are important here, as the door frame is relatively thin.
Another option is to replace the doors entirely or to combine with separate display cabinet doors from other ranges (e.g., BESTÅ), provided the sizes are compatible, although this is often impractical.
My advice: If glass fronts are important, carefully consider whether the aesthetic benefits justify the effort involved in modifications, stability, and installation.
Could you please specify the intended size and purpose of the glass fronts? Dust protection, visibility, lighting?
Palenar schrieb:
Officially, IKEA currently does not offer glass fronts for PLATSA, which is also due to the design – the doors are not specifically made for glass panels, meaning they do not have built-in glass inserts or the necessary mounting elements.This is an important point that is often overlooked. Many simply want to add “glass fronts” to the PLATSA system without considering how crucial the door frames are designed for this purpose.
Furthermore, I think the question arises: What requirements should these glass fronts meet? Are they purely for aesthetics, or do they need to fulfill stability and safety standards as well? Of course, DIY solutions with plexiglass are an option, but such modifications can become problematic for everyday use, especially in households with children or pets.
In addition, I would be interested to know how the original poster plans to manage the connection details of the glass fronts to the hinge areas. These are firmly attached to a flat door panel, which in PLATSA is usually made of wood-based panels. A clear glass partition therefore requires correspondingly secure fastenings.
Hello Par35,
I can relate to your question well, as I recently faced a similar decision myself.
As of now, IKEA does not offer glass fronts as a standard option for PLATSA. Although there are glass doors available for other series such as BESTÅ, the construction of PLATSA is too different to simply swap them.
If you are comfortable with DIY, you can insert glass or plexiglass into certain door frames using appropriate rubber profiles or build your own frames. It is important to choose something sturdy, possibly with holes for screws, so the glass does not shift.
I also recommend selecting the type of glass carefully:
- Clear glass looks elegant but shows fingerprints and dust quickly
- Frosted or satin glass provides privacy and can conceal untidy interiors
- Safety glass or tempered glass is advisable to prevent hazards if the glass breaks
For your project, you might also consider using doors with integrated glass or separate glass display cabinets instead of pure glass fronts, using PLATSA mainly as the base frame.
If you want more information on how to technically carry out the modification, feel free to ask!
