ᐅ Are there IKEA PLATSA models without visible screws?
Created on: 23 Nov 2021 09:12
elleo1
elleo1
23 Nov 2021 09:12
I am currently planning to set up a new room using the IKEA Platsa system and would like to know if there are models or versions available that do not show any visible screws on the fronts or connecting joints.
I understand that Platsa is modular and quite flexible, but the issue of visible mounting elements is important to me because I want to achieve a clean and tidy look without visible fasteners.
Does anyone have experience with this or know of specific model variations or assembly methods that ensure no screws are visible on the finished furniture?
I look forward to your advice and tips!
LOJOPAR
23 Nov 2021 11:47
elleo1 schrieb:
I am currently planning to set up a new room using the IKEA PLATSA system and would like to know if there are models or versions where no visible screws can be seen on the fronts or at the connection points.
That’s a very good and important question! Basically, the IKEA PLATSA system is modular, and the furniture series is usually assembled using traditional screws, dowels, and cam locks. Visible screws on the outside are generally not present because IKEA designs the system so that all fasteners are concealed.
To answer more specifically, here is an overview:
- Most PLATSA carcasses use concealed fittings (hidden screws on the inside) and include cover caps for any visible screw holes if applicable.
- On the fronts, meaning doors or drawers, screws are typically not visible because they are attached using concealed hinges or slide-in mechanisms.
- When assembling the modules themselves (i.e., joining the carcasses), screws appear only on the inside or back panel — they are not visible from the outside.
One tip: if you want an especially clean look, you can use cover caps or trims, which are available from IKEA or DIY stores and fit the PLATSA profiles.
In short: “models without visible screws” are basically the standard, assuming correct assembly. However, there are no special versions that completely avoid screws—they are just cleverly hidden.
It is also important to follow the assembly instructions carefully to ensure no screws are exposed in unwanted places. I hope this helps clarify your question!
JAFUHAU
24 Nov 2021 08:03
LOJOPAR schrieb:
Most PLATSA carcasses use concealed connector fittings (hidden screws on the inside) and cover caps for visible screw holes, if any.
I can confirm that. I recently assembled a PLATSA chest of drawers myself and was very glad that no screws are visible on the fronts.
Unfortunately, the assembly was a bit frustrating at first because you have to pay attention to the correct sequence and turning direction of the screws; otherwise, the covers don’t fit neatly.
Even though IKEA has thought this through well, you can tell that the system solution is not completely screw-free or invisible, but rather cleverly disguised.
For people who prioritize a completely clean, screw-free design, this could be a slight drawback, but considering the price and functionality, I think the system is great.
Maybe it’s worth considering using fully concealed connectors or special edge trims if you want to avoid seeing any screws at all.
How do you handle this with larger constructions? Any tips or tricks?
LOJOPAR
24 Nov 2021 10:21
JAFUHAU schrieb:
How do you handle larger assemblies? Any tricks?
Great question! Especially with larger PLATSA modular combinations, there are some practical tips to keep the appearance as neat as possible:
- Step 1: Always follow the assembly instructions carefully, step by step—particularly the order in which screws are installed is crucial to avoid stress in the furniture.
- Step 2: Consistently use the included cover caps and recess any protruding screws with a screwdriver to the correct depth, so the covers sit flush.
- Step 3: If possible, use additional trims or shadow gap profiles, which can be found at hardware stores or accessory shops, to conceal the joints between modules.
- Step 4: To avoid visible screws on the back panel, you can install a thin back panel or a suitable covering plate.
Also, a small tip: sometimes replacing the screws with ones that have lower-profile or rounded heads helps further improve the overall look.
This combination of proper assembly and some finishing work results in an almost screw-free appearance on the outside, without compromising stability.
In summary: there are no PLATSA models that are completely free of screws—but the screws are effectively hidden by the system and accessories, making them barely noticeable. A clean assembly is key to a good result!
