ᐅ Are there IKEA PLATSA models that are specifically designed for bathrooms?
Created on: 8 Mar 2020 14:23
Labere
Labere
8 Mar 2020 14:23
Hello everyone, I have a rather specific question and hope to get your expertise: Are there actually IKEA Platsa models that are specially designed for use in bathrooms?
I’m not only referring to purely aesthetic adjustments, but especially practical features like moisture resistance, specially adapted materials, or system-based solutions for bathroom storage (e.g., cabinet modules that work better with bathroom mirrors, vanity units, or humid environments).
Has anyone had experience whether IKEA offers truly optimized versions for bathrooms, or if you have to rely on standard Platsa models that might then be modified with your own accessories or finishes to suit a bathroom?
I’d appreciate any information, tips, or experiences, including advice on common pitfalls when using Platsa in the bathroom.
KODAN32
8 Mar 2020 15:04
regarding your question: IKEA PLATSA is basically a very flexible system that covers many applications. However, for bathrooms, two aspects should be distinguished:
- Materials: PLATSA modules are mostly made of engineered wood panels that are not specially treated for moisture resistance. This means in highly humid areas, additional measures or extra coatings are necessary.
- Design/Modifications: There is no specific "bathroom edition" of PLATSA. However, IKEA offers fronts with plastic coating, which are better protected against splashes.
Tips:
- Ensure sufficient ventilation when using the system
- Use plastic-coated fronts or water-resistant paints
- Avoid placing cabinets directly on the floor to prevent trapped moisture
In short: optimized here means "upgradable" rather than "ready for bathroom use." For dedicated bathroom furniture, IKEA generally recommends other lines (e.g., Godmorgon).
V
Victor54
8 Mar 2020 15:47
KODAN32 schrieb:
There is no special "bathroom edition" of PLATSA.
This is a clear statement, but it should be considered from several perspectives. Why doesn’t IKEA offer versions of PLATSA specifically designed for moisture resistance?
In my assessment, it’s because PLATSA is a modular system intended for versatile living room and bedroom furniture. The demands of a bathroom—such as humidity, splashing water, and droplets—require specialized materials.
If IKEA were to really invest in this segment, production costs and price levels would have to be adjusted, which would not align with the PLATSA concept.
It is also interesting to consider whether customers adapt PLATSA themselves with varnishes or laminates to make it "suitable" for bathroom use. This would essentially render the question of “optimized models” irrelevant.
pikin
9 Mar 2020 09:36
In addition to the previous explanations, I can confirm the following:
IKEA PLATSA does not include any specific products or components explicitly certified or designed for damp environments, such as bathrooms.
From a material perspective, most panels are made of medium-density fiberboard (MDF) or particleboard, which are only moderately resistant to moisture.
This means that using them in bathrooms is only advisable with appropriate precautions:
- Avoid direct contact with water
- Use water-repellent fronts or finishes
- Install in well-ventilated areas
- Protect with baseboards or spacers to keep them off the floor
As a supplement: IKEA offers the GODMORGON series, which is specifically designed for bathroom needs and features water-resistant surfaces.
Anyone wanting to use PLATSA in a bathroom should consider applying their own waterproofing treatments, UV-resistant and water-resistant coatings, and pay close attention to installation to prevent moisture damage.
Garthre
9 Mar 2020 11:51
Regarding the specific question: "Are there IKEA PLATSA models optimized for bathrooms?" it can be said that IKEA does not offer official PLATSA bathroom models equipped with special moisture protection.
The modular PLATSA system is primarily designed for living rooms or bedrooms, where humidity is not a major concern.
My advice for anyone who still wants to use PLATSA in the bathroom: use the plastic fronts or apply water-resistant clear varnish to the surfaces yourself to improve resistance against splashing water.
Another option is to avoid placing the cabinets directly against the wall behind the shower, instead positioning them in drier areas. After all, proper cleaning and ventilation are crucial for durability.
Although there are no specially optimized PLATSA models for bathrooms, with some minor adjustments, the furniture can certainly be used without immediate damage.
