Good morning everyone,
I am currently planning a new cabinet system and have been looking at the IKEA Platsa series. My question to the community is: Are there any versions or accessories for the PLATSA furniture that allow for soft-close doors?
It is important for me to know whether soft-close hinges come standard or if there are reliable retrofit options that fit well and work dependably.
Has anyone had experience with this, maybe recommendations for parts or DIY solutions?
Thanks for your help!
To supplement the previous information:
Currently, there is no official IKEA Platsa version with integrated soft-close doors. For retrofitting with soft-close hinges, Blum and Hettich are the most common and reliable brands. However, caution is advised when working with Platsa because:
- The drill holes on Platsa doors do not always match the standard 35mm (1.38 inch) diameter cup hole and are sometimes offset.
- Installing universal hinges may require additional work such as drilling or adjustments.
In everyday use, many users report satisfactory soft-close performance when the hinges are installed correctly. The damping works reliably and significantly improves comfort. It is recommended to test a sample hinge before purchase.
If you want the soft-close function professionally installed and without modifications, it is probably better to choose other IKEA systems such as Metod or Besta, which come with soft-close features as standard.
I retrofitted my PLATSA cabinet with soft-close hinges myself and I’m really impressed!
It takes a bit of tinkering, but the result is great: no more loud slamming, everything closes smoothly and quietly. I used Blum hinges, which fit perfectly for me with a little adjustment.
It’s definitely worth it, especially if you have small children or sensitive neighbors. Just give it a try and don’t get discouraged!
Leonardteo4 Sep 2020 08:47Summary and Final Note:
- IKEA PLATSA furniture does not come with factory-installed soft-close hinges.
- Retrofitting with soft-close hinges from third-party manufacturers is possible, but not always plug and play.
- Compatibility of the drilling patterns is especially important, as PLATSA may differ from the standard.
- Blum hinges are the most commonly recommended and usually require minor DIY adjustments.
- For those who want a guaranteed and straightforward solution, it may be better to consider other IKEA systems.
For users with some DIY skills, retrofitting can be a worthwhile improvement.
