Good morning everyone,
I am currently planning a new cabinet system and have been looking at the IKEA Platsa series. My question to the community is: Are there any versions or accessories for the PLATSA furniture that allow for soft-close doors?
It is important for me to know whether soft-close hinges come standard or if there are reliable retrofit options that fit well and work dependably.
Has anyone had experience with this, maybe recommendations for parts or DIY solutions?
Thanks for your help!
Hey,
I had the same issue with my PLATSA cabinet. At first, I was quite disappointed because I really appreciate soft-close functionality and want the doors to close gently. After some research and testing different hinges from third-party manufacturers, I found a suitable solution that holds up well.
It was also important to me that the hinges are easy to install by myself without damaging the furniture. If that’s an option for you, it’s definitely worth trying out these kinds of solutions. Good luck with your project!
Landontau2 Sep 2020 11:03Regarding the question of whether PLATSA furniture comes with soft-close doors, here is a detailed explanation:
1. IKEA does not seem to use soft-close hinges on PLATSA furniture as standard.
2. However, the soft-close function can usually be retrofitted if the drill holes and door dimensions match.
3. It is best to:
- Choose hinges with a clip-on mechanism
- Check measurements carefully, as PLATSA is a proprietary cabinet series with specific drilling patterns
- Follow the installation instructions of the new hinges closely
For practical tips:
- Remove the doors completely
- Take off the old hinges
- Attach and adjust the soft-close hinges
Retrofitting is definitely possible but requires some basic DIY skills.
3. It is best to:
For practical tips:
I would like to add:
That’s exactly the point. PLATSA has its own somewhat unusual drilling pattern. Some users report that conventional soft-close hinges with standard drilling patterns do not fit without modifications. Particularly important:
- precise measurement of the cabinet doors
- possibly slight adjustments during installation
Also: IKEA hinges from other product lines (e.g., METOD) are not compatible, so be careful when choosing. Soft-close can be achieved, but it is important to research thoroughly beforehand to avoid purchasing mistakes.
Landontau schrieb:
The soft-close feature can usually be retrofitted if the drill holes and door dimensions match.
Thank you for the early responses!
@Aimee and @Landontau: Could you recommend which brands or models to focus on for retrofit hinges? I’ve read that the common BLUM clip-on systems are often recommended, but I’m unsure about the drilling patterns.
Also, I’m curious how well the soft-close function actually works in everyday use when not using the original IKEA solution.
