ᐅ Are there IKEA Platsa units with built-in vacuum cleaners?
Created on: 11 Dec 2024 14:07
Toluke
Toluke
11 Dec 2024 14:07
Hello everyone, I have a rather specific question regarding the IKEA Platsa furniture series. Specifically, I am interested in whether IKEA offers Platsa furniture with an integrated vacuum system or if there are modular components available that would allow this. I am looking for a solution that enables vacuum technology to be discreetly and permanently built into a piece of furniture, to efficiently and unobtrusively remove dust and dirt in the living area. Does anyone have experience with this or know of product variants or DIY solutions within the IKEA Platsa system that come close to a built-in vacuum? I look forward to your opinions and tips.
Domau0
11 Dec 2024 14:22
Hello Toluke,
Regarding IKEA Platsa and integrated vacuum cleaners, I can share the following from a technical perspective: To my current knowledge, IKEA does not offer Platsa modules with built-in or pre-installed vacuum cleaners. The Platsa series is modular and designed for storage, such as drawers, shelves, and cabinets, but does not include integrated household appliances.
If you are looking for a built-in or permanently installed vacuum solution, there are central vacuum systems available in other areas of home technology. These are installed via piping systems, which could theoretically be hidden behind furniture like Platsa, but this is not something IKEA typically provides as a standard feature.
What is possible are DIY custom solutions: for example, leaving a narrow recess in the furniture to accommodate a cordless vacuum cleaner, such as a Dyson, with its charging station concealed. However, this requires precise planning regarding dimensions, ventilation, and electrical connections.
I would be interested to know whether you are referring to a fully integrated vacuum cleaner that starts at the push of a button within the furniture, or if you simply want a vacuum cleaner stored as elegantly as possible. This would help narrow down the search.
Toluke
11 Dec 2024 14:35
Domau0 schrieb:
I’m curious whether you mean a fully integrated vacuum cleaner that starts at the push of a button within the furniture, or if you just want a neat way to store a vacuum cleaner? Clarifying this would help narrow down the search.
Thanks for asking. Yes, I’m thinking more of a technically integrated solution—not just a convenient storage option for a cordless handheld vacuum, but a properly built-in system: possibly with a suction function that can be activated through the furniture. For example, where you could pull a hose or something similar directly from the furniture, or where the furniture itself could provide suction power at multiple outlets. I’m not sure if IKEA Platsa offers this, but maybe there are accessories or compatible expansions? I hope this clarification helps.
Filippo
11 Dec 2024 15:19
Hello Toluke,
I would like to share some technical details from my experience that might help you. The idea of fully integrating a vacuum cleaner into a piece of furniture like Platsa is quite challenging, as there are several factors to consider:
- Power supply: A built-in vacuum cleaner requires fixed electrical wiring as well as safety devices.
- Ventilation and heat management: Vacuum motors generate heat and need well-ventilated housings.
- Mechanics and accessibility: Pulling out a hose or nozzle must be ergonomic without causing major damage to the furniture.
IKEA, as a furniture manufacturer, focuses on standardized, modular furniture designed for flexible combinations. A fully integrated vacuum function is more common in custom-built furnishing systems, often in high-end kitchens or utility rooms, but not for standard storage furniture like Platsa.
For central vacuum systems, modifications within walls or built-in cabinets are common, but not within serialized furniture from IKEA.
Personally, I recommend that if you are looking for a custom vacuum solution, you might consider a cordless vacuum combined with a tailor-made built-in cabinet or look into an external central system. Of course, DIY enthusiasts with crafting skills could use the Platsa system to build some kind of docking station for a vacuum or its accessories, but not with a fully integrated suction function.
If you like, I can also provide some technical alternatives to integrated vacuum cleaners that can be well incorporated into living space furniture.
Nabla64
11 Dec 2024 16:02
to help structure the discussion a bit, here is a brief overview of the options related to Ikea Platsa furniture and vacuum cleaners that exist or could be possible:
- IKEA does not sell Platsa components with a built-in or permanently integrated vacuum cleaner.
- However, there are sets and modules specifically designed for organizing and storing cleaning supplies and even vacuum attachments, but these are storage furniture only, not active devices.
- A simple and commonly used DIY method is placing a cordless Dyson or similar vacuum cleaner inside a Platsa cabinet compartment with a suitable charging station.
Summary/tip:
- If you want a true integration with suction functionality built into the furniture, custom fabrication and technical installation are mostly unavoidable.
- For everyday use, clever storage of the vacuum is usually sufficient – Platsa’s modular dimensions often allow for a suitable combination.
I also recommend careful planning: check dimensions and connection options in advance so you don’t have any surprises later.
If you are interested in DIY solutions, I’d be happy to explain how to implement mounting brackets and power supply for Platsa, for example.
Paunon
11 Dec 2024 16:27
Briefly on the question: IKEA Platsa does not offer furniture with built-in vacuum cleaners.
For integration, central vacuum systems or custom brackets for cordless models within the furniture are more suitable.
Anything else requires individual modification.
