á Are there IKEA PLATSA units with sliding or rolling features?
Created on: 18 Aug 2021 09:37
neodaHello everyone, I am considering buying some IKEA PLATSA furniture for my home and am particularly interested in models with wheels. My question is: Are there any versions or extensions of the IKEA PLATSA furniture that come equipped with wheels or are designed to be easily moved? I havenât been able to find clear information about this online, and Iâm especially curious if there are official IKEA solutions, such as drawer-like modules on wheels or complete cabinets with wheels, that enhance convenience and flexibility. Maybe someone here knows about this or has practical experience? Thanks in advance for any helpful feedback!
Regarding the question of whether IKEA PLATSA furniture comes with wheels, it can be said that IKEA does not offer, to my knowledge, any PLATSA furniture with built-in wheels in the standard range. PLATSA units are primarily designed to be mounted on the wall or used as stationary furniture. Therefore, there are no officially integrated wheels or mobile bases directly provided by IKEA. If mobility is desired, you can of course use wheels from other IKEA product lines and install them separately; however, you need to consider the load capacity and secure attachment. Overall, PLATSA is more of a flexible wall system than mobile storage.
Karsten4518 Aug 2021 11:22Hey, great question! I did some research and testing â IKEA PLATSA with casters? Officially, they donât seem to offer them, but thatâs no reason to stop having fun đ. You can use casters from IKEA (for example, from the BekvĂ€m stool) and attach them to the modular PLATSA bases â it takes a bit of DIY, but it makes the units very mobile. Note: Itâs better to use casters with brakes, otherwise the cabinet might roll away if you accidentally bump into it. So, if you like flexibility, you can definitely get a lot out of this DIY approach.
GUSTAVO5618 Aug 2021 13:46Interesting topic! To address the technical side: IKEAâs PLATSA series is primarily designed for stable placement and wall mounting. The frames and connectors are optimized to create sturdy furniture units, rather than easily movable or transportable pieces. In theory, wheels can be attached to the bases, but the following points should be considered:
- The load capacity of the wheels must match the weight of the fully loaded furniture.
- The mounting points are not specifically designed for wheels, so additional reinforcement may be necessary.
- Any modifications to the PLATSA components could affect warranty and return conditions.
Therefore, anyone considering a rolling function should carefully plan how often and to what extent movement is needed and check the technical requirements of the wheels. Another important factor is whether the floors are level enough, as uneven surfaces can quickly cause problems. Is there a specific use case where mobility is essential?
GUSTAVO56 schrieb:
Any modifications to the PLATSA units could affect warranty and return conditions.This is a very important point! Anyone making modifications to IKEA furniture does so at their own risk. If you want to add casters (wheels), I recommend the following approach:
- Step 1: Choose a sturdy substructure (frame or base) to which the casters can be attached.
- Step 2: Use casters with a load capacity at least 1.5 times the weight of the fully loaded cabinet.
- Step 3: Securely install the casters and check the stability before filling the unit.
Additionally, you can add some anti-slip pads or brakes to prevent unwanted rolling. This is especially useful if you want to move the furniture frequently, for example, in a multipurpose room or small spaces. IKEA does not officially offer a complete solution for PLATSA units with casters, but DIY works very well if done carefully.
Giagau schrieb:
PLATSA modules are primarily designed for wall mounting or as freestanding furniture pieces.Thank you, that already clarifies a lot. I mainly want to use a PLATSA unit that I can move around occasionally to keep the room layout flexible. Mounting it on the wall would probably be difficult in this case.
GUSTAVO56 schrieb:
Is there a specific use case where mobility is absolutely necessary?Exactly, I have a small home office and guest room, and I would like to be able to easily move the cabinet when needed, for example, for cleaning or if guests require a different setup at short notice. An integrated rolling function or an age-appropriate mobile unit would really help without having to do a complete redesign. Does anyone in the community have experience with practical solutions for this that donât damage the modules?
