ᐅ Are there Ikea PAX wardrobes available with adjustable heights?
Created on: 29 Aug 2023 09:13
albert44Hello everyone,
I have a special challenge with planning a wardrobe in my apartment due to a sloped ceiling. Therefore, I am wondering if the Ikea PAX wardrobe series offers models with adjustable heights, meaning wardrobes whose height can be customized or at least flexibly assembled. My specific question is: Are there different height options available within the Ikea PAX wardrobes that can be combined to create a tailor-made height? Or are the wardrobes fixed in standard heights, so I would need to consider other solutions?
Thanks for your expertise!
The PAX wardrobes come in several fixed heights, usually 201 cm (79 inches), 236 cm (93 inches), and 271 cm (107 inches). There is no option for individual height adjustment directly on the wardrobe. However, the height can be slightly adjusted by combining different cabinet sections and plinths.
Hello Albert,
Regarding your question about variable heights for Ikea PAX wardrobes: Basically, PAX offers modular components, but the main carcasses come in three standardized heights (as nonpra already mentioned). The flexibility mainly comes from combining individual carcass units (e.g., 50cm (20 inches) or 75cm (30 inches) wide modules), rather than adjustable height within a single wardrobe carcass.
What you can do to match a specific room height are retrofitting options, such as placing a base with the appropriate height under the carcass or covering the top of the wardrobe with a panel. Additional parts like toppers are also available, but they have fixed dimensions as well.
If you want to precisely fit a sloped ceiling, you can try choosing the tallest wardrobe possible and fill the remaining space with custom-cut coverings made of wood or drywall.
I’m curious about how much tolerance you actually need—how much does your slope vary? Do you already have a detailed plan or just a rough idea? Sometimes, with clever planning, you can achieve good results even with the standard sizes.
Hello Albert,
your question is very understandable and concerns many people living in apartments with sloped ceilings. The PAX series is indeed very versatile, but the basic dimensions of the carcasses are actually fixed to a few standard heights. Ikea does not really offer height adjustability in the proper sense.
What I would recommend:
- Use the 201 cm (79 inches) or 236 cm (93 inches) PAX carcasses as a base.
- Build a plinth or a platform if slight height differences need to be compensated.
- To adapt to the slope, use so-called filler panels or extension parts, which are also offered by Ikea.
This way, you cannot adjust every centimeter in height individually, but you can adapt flexibly. However, if you have very unusual or steeply sloped roof surfaces, custom-made solutions might be a better choice.
In general: The PAX system is modular but designed for standardized dimensions – this allows for cost-effective manufacturing but no continuous height adjustment.
Hello Albert,
to answer your question in detail, here is a structured overview:
- Ikea PAX wardrobes are based on fixed main carcass heights: 201 cm (79 inches), 236 cm (93 inches), and 271 cm (107 inches).
- These heights are not adjustable, meaning you cannot simply change the height of a carcass by repositioning it.
- Adjustments are made through:
- Plinth heights: Ikea offers various plinths that are installed under the carcass, typically between about 8 and 15 cm (3 and 6 inches) high.
- Top panels/cover strips: To fill the space above for a clean finish.
- When dealing with sloped ceilings, it is often advisable to choose the tallest wardrobe and close the remaining space with panels or custom fittings.
Common mistakes I often see:
- Trying to adapt the wardrobe exactly to the slope’s peak by sawing or modifying carcass parts – this often leads to stability issues.
- Not using or underestimating the plinth – increasing the plinth height by 10 cm (4 inches) can effectively adjust the total wardrobe height.
Conclusion: There are no variable heights, but by combining the three carcass sizes with plinths and cover strips, you can plan quite flexibly. If you need deeper insights, feel free to ask – I can also assist you with planning.
