ᐅ Are there Ikea Pax wardrobes with sturdy sliding doors?
Created on: 24 Jan 2024 10:13
kuren65
kuren65
24 Jan 2024 10:13
Are there Ikea Pax wardrobes with durable sliding doors designed specifically for heavy use? I plan to buy a Pax wardrobe with sliding doors but am unsure how sturdy and long-lasting Ikea’s sliding door systems really are. My main question is whether there are Pax models with reinforced or particularly robust sliding doors that have proven reliable in daily use—especially if the doors are opened and closed frequently or if the wardrobe needs to support extra weight. Are there any users with experience or specific recommendations? Thanks in advance.
Ramon4
24 Jan 2024 10:45
Hello! Basically, the Pax sliding doors from Ikea are designed for regular residential use, such as daily opening and closing in a bedroom or hallway. There are no specially reinforced or heavy-duty versions intended for industrial or very rough use. However, you should make sure to install the tracks properly and avoid subjecting them to excessive stress.
Most users report that the doors are quite durable when installed and used carefully. However, if you are looking for a closet with particularly heavy use, it might make sense to invest in higher-quality sliding door hardware or have the system professionally adjusted.
An alternative would be to use standard hinged doors or folding doors instead of sliding doors if durability is your primary concern.
Leote
24 Jan 2024 11:07
Pax sliding doors are sturdy enough for residential use. There are no special "heavy-duty" versions available.
If you want more stability, it is better to choose hinged doors.
Josefane
24 Jan 2024 12:22
Ramon4 schrieb:
However, you should make sure to install the tracks properly and avoid placing excessive stress on them.
That is an important point. I find the discussion around “durable” sliding doors to be somewhat vague, because what exactly does durable mean in this context? Load capacity, longevity, or material quality?
In my experience, Pax sliding doors are not components designed to last for decades with continuous use, unlike high-quality custom-made wooden doors with metal tracks.
Are there any concrete experiences with long-term use? I ask because many Ikea furniture pieces tend to fall apart after a few years under heavy use. It would be interesting to discuss this with examples.
GOLO42
25 Jan 2024 09:05
I agree with the previous assessment but would like to add some technical details. The Pax sliding doors typically use aluminum frames with inset panels (wood-based material or glass). The tracks are usually made of plastic or metal with plastic gliders.
- The load capacity strongly depends on the correct installation of the tracks.
- The longer and wider the doors, the more stress is placed on the tracks and rollers.
- The doors are not designed to carry heavy additional loads (e.g., added weights or attachments).
If durability is your top priority, you might consider investing in upgraded rollers or even using external track systems from third-party suppliers that offer higher-quality materials and load capacity.
Finally, take a closer look at how you will be using the doors. If they will be operated multiple times daily with high force (e.g., small children who may be less careful), I recommend considering an alternative solution or modifying the system.
kuren65
25 Jan 2024 10:20
Josefane schrieb:
I ask because many Ikea furniture pieces fall apart after a few years under heavy use.
Thank you for this critical perspective. Yes, I share these concerns exactly. My requirements include daily use of more than five openings and closings, and the door is sometimes subjected to more pulling or pushing than with careful handling.
Long-term experience from the community would be ideal to assess whether I am exposing myself to a fundamental risk of wear or even failure with the Pax sliding doors.
I am also interested in how the system is exactly constructed at Ikea — in other words, whether the sliding doors are a permanently installed complete system or if individual components like tracks and rollers can be replaced or upgraded to improve durability.
