ᐅ Are there Ikea Pax wardrobes with built-in LED lighting?
Created on: 4 Oct 2022 09:23
Lotteti
Lotteti
4 Oct 2022 09:23
Hello everyone, I am currently planning to get a Pax wardrobe from Ikea and was wondering if this model is also available with integrated LED lighting. I have specifically been looking for a solution where the LED strip or lighting system is built directly into the wardrobe to provide even illumination inside, without needing any additional retrofit installations.
I am especially interested to know if Ikea itself offers such versions or if you always have to rely on third-party products or custom modifications. Does anyone have experience with this or know of products in Ikea’s range that include integrated LED lighting within the Pax system?
I would appreciate any information on technical details, any existing modules, control options (e.g., sensors or remote control), and, of course, practical tips for installation. Thanks in advance!
tra_nina
4 Oct 2022 11:47
Hello Lotteti,
Ikea does not offer integrated LED lighting pre-installed in the Pax system cabinets. This means the cabinets come without fixed lighting. However, Ikea sells separate LED modules specifically designed for Pax. These can be mounted on shelves or on the top underside of shelves. The lighting is usually designed to be connected to the power supply via plug and cable, and some modules also work with motion sensors.
If you are looking for a fully "integrated" solution that is permanently and invisibly installed, you will not find this in Ikea’s standard range; you will need to retrofit it yourself or consider third-party products. Many users, for example, install LED strips with adhesive backing inside the doors or at shelf heights.
Control is mostly done via switches or motion sensors, and smart options with app connectivity are not directly offered by Ikea. However, there are smart home-compatible solutions that can be retrofitted with the appropriate technology.
In summary:
- No Pax cabinet with factory-integrated LED lighting
- Ikea LED lights usable as additional elements
- Motion sensors available for some modules
- For fully invisible and smart solutions, DIY or third-party products are recommended
Hope this clarifies your question well. If you need more details about installation, feel free to ask.
sifope
4 Oct 2022 15:09
tra_nina schrieb:
Ikea does not offer integrated LED lighting in the Pax system that is factory-installed.
Interesting point, but isn’t it somewhat misleading to say Ikea has “no integrated lighting” when they do offer their own LED panels that fit very well into the Pax units? They may not come pre-installed, but these are officially part of the product range and designed specifically for the system – which could reasonably be called a form of "integration," at least modular and officially supported.
Furthermore, I wonder if the separate installation of these LED panels is really as straightforward as Ikea suggests. There are many reports indicating that cable routing and installation can be quite complex, especially with larger Pax configurations. Are there reliable user experiences on how well DIY installation actually works?
Also relevant is the question of compatibility with smart controls: Ikea offers the TRÅDFRI system, but can its technology be connected with the Pax lighting, or is third-party equipment needed for that?
Overall, I think it’s important to use terminology carefully, especially since users might expect lighting to be immediately “out of the box” integrated. That is currently not the case – I agree – but the availability of suitable and system-specific modules from Ikea should not be underestimated either.
PAREL
5 Oct 2022 08:32
To supplement, here is a structured overview that everyone planning lighting for Pax should consider:
1. Products from Ikea:
- LED modules specifically designed for Pax: mostly available as shelf lights or side rails
- Motion sensors for automatic control
- No complete solution with built-in LED systems in the cabinet frame
2. Installation notes:
- Cables must be routed manually and usually connected centrally
- Ensure there are enough power outlets nearby or use cable extensions
- Cable ducts or clips are recommended for a neat appearance
3. Smart control:
- The IKEA TRÅDFRI range offers smart bulbs and control devices
- Retrofit kits for motion sensors or Zigbee-compatible dimmers can be used
- Not all LED modules for Pax are TRÅDFRI-compatible, check before purchase
4. Alternatives and third-party products:
- LED strips with 12V or 24V often work better for continuous lighting
- There are custom retrofit plexiglass rails with LEDs for plexiglass doors in Pax
Summary: The Pax itself comes without integrated lighting, but Ikea produces compatible LED accessories. Those seeking enhancements and smart solutions should consider both installation and control options and possibly rely on third-party products that offer extended features.
Naomige
5 Oct 2022 12:17
sifope schrieb:
Ikea has the TRÅDFRI system—can its technology be combined with the Pax lighting, or do you need third-party products for that?
Here is an additional explanation: Ikea’s TRÅDFRI modules generally work with Pax accessories when the lights use standard GU10 sockets or compatible LED bulbs. However, not all LED panels in the Pax range are TRÅDFRI-compatible out of the box, as some use simpler plug solutions.
It is also important to know that direct integration into a smart home often requires a TRÅDFRI gateway, which can be controlled via remote as well as an app.
For beginners, the system may seem somewhat complex: you need to carefully consider which modules to use and whether a power outlet is within reach. Additionally, motion sensors can be a practical feature in some Pax configurations, automatically turning lights on and off when the cabinet is opened or closed.
So, for those who want convenience without having to solder or do electrical work themselves, Ikea offers simple solutions that can still be integrated smartly—though compromises in flexibility and aesthetics are often necessary.
For anyone who just wants basic lighting, Ikea’s LED modules are entirely sufficient. For customized, fully integrated solutions with batteries and concealed technology, however, DIY builds or specialized providers are recommended.
