ᐅ Are there Ikea Pax wardrobes available with built-in mirrors?
Created on: 24 Apr 2018 17:23
POBRUCEHello everyone, I am currently planning my new bedroom and would like to incorporate an Ikea PAX wardrobe. My specific question is: Are there any Ikea PAX wardrobes that come standard with built-in mirrors on the doors or inside the wardrobe? It is important to me to find a solution where the mirror is firmly integrated into the wardrobe itself, not just as a separate, optional accessory or an additional part to be attached. I am looking for a finished, built-in mirror effect that belongs visually and functionally to the wardrobe. If this is not the case, I would be very interested in any experiences on the best ways to attach mirrors to PAX wardrobes in a functional and aesthetic manner, whether there are doors with exact-fitting mirrors or other recommended options. Thank you very much in advance for your support!
Hello POBRUCE, your question is very well formulated and shows that you are already familiar with some details about PAX wardrobes. To get straight to the point: Ikea does indeed offer different doors for the PAX wardrobe, including doors that are fully mirrored. These mirrored doors are usually available as fronts that can be mounted directly onto the wardrobe frame. The mirror is already permanently integrated into these doors, so they are not loose accessories.
There are some important points to consider:
- The mirrored fronts mostly come in a classic, slim design but are only available for certain door models (e.g., “mirror door white” or “mirror door black”). There are no mirrors installed inside the wardrobe – the mirrors are almost always fixed on the outside of the door.
- The installation is basically the same as with regular wardrobe doors, but due to the weight of the mirror, you should pay special attention to using sturdy hinges.
- In some cases, the mirrored surface may be framed with wood or metal, depending on the chosen model.
- Optional three-part mirrored doors are available for corner solutions, or sliding doors with mirrors.
In conclusion: If you are looking for a PAX wardrobe with a built-in mirror, you can order corresponding mirrored doors directly from Ikea. A combination with separate mirrors inside the wardrobe is not part of the standard offering and would need to be solved individually.
For a better recommendation: What size and type of doors do you have in mind? Are you focusing on a classic hinged door or a sliding door? The latter has a different hinge system and other door options.
POBRUCE schrieb:
Are there Ikea PAX wardrobes that come standard with built-in mirrors on the doors or inside the cabinet?The PAX system from Ikea is offered with a variety of doors, some of which are fully mirrored. These mirrored doors are part of the regular product range but can only be installed as external fronts on the wardrobe. Ikea does not offer built-in interior mirrors on the cabinet sides or inside the wardrobes as a standard option.
Important to know:
- Mirrored doors are available for both hinged doors and sliding doors.
- Installation is the same as with regular doors.
- Ikea offers several color options and frame styles for mirrored doors.
- For adding extra mirrors inside the wardrobe, separate mirror panels need to be purchased and installed.
Conclusion: For a fixed, integrated mirror surface on the wardrobe, mirrored doors are the right choice. Interior mirrors are not standard. The decision to choose mirrored doors depends on your available space and design preferences.
CHARLES6926 Apr 2018 22:37Hey, great topic – I love my PAX wardrobe with mirrored doors! 🙂 Ikea actually offers doors that are fully mirrored, and they look fantastic! They save space since you don’t need a separate mirror in the room, and they look really stylish. I have exactly that kind of wardrobe at home and can highly recommend it.
If you want a touch of luxury, pay attention to the hinges – they need to be strong enough to support the weight of the mirror. Assembly is easy, and the mirror glass is securely fixed, so no more loose or wobbly mirrors. If you like, I can also share some tips on the best way to clean the mirrored doors and how to quickly remove fingerprints.
What I really like: there are also elegant black-framed mirrored doors that add a really cool style to the bedroom. So, if you care about design and practical use, go for the PAX with mirrored doors!
Good luck with your project, you’re going to love it!
