ᐅ Are there versions of Ikea Pax wardrobes with particularly strong shelves?
Created on: 22 Oct 2023 14:37
manabidinM
manabidin22 Oct 2023 14:37Hello everyone,
I am currently looking into the Ikea Pax wardrobe and seeking more detailed information regarding the stability of the shelves. My question is: Within the Ikea Pax system, are there specific types of shelves that are particularly sturdy or better suited for heavy loads? I want to use the furniture as long as possible and be able to store heavier items like thick books or electronic devices without the shelves sagging or getting damaged.
Standard particleboard shelves often seem quite thin, especially when they are wide – so I am wondering if there are alternative options, such as shelves made from more durable materials, with reinforcements or additional supports. It would be great if someone could share experiences or well-founded tips. Thanks!
Hello manabidin,
your question is very well formulated and important, especially because the load capacity of shelves in wardrobes is often underestimated.
First of all: Ikea generally offers shelves made of particleboard in the Pax system, which are usually about 16 mm (0.6 inches) thick. These are designed mainly for regular storage, such as lighter clothing or smaller items.
However, there are several ways to improve stability:
- Ikea occasionally sells reinforced shelves, for example made of thicker materials or with metal reinforcements – but these are not always available nationwide or permanently in the range.
- A proven method is to use additional shelf supports and brackets. These help to prevent sagging.
- You can also turn to third-party suppliers who offer custom or reinforced shelves made of plywood or MDF, often available in 18 or 22 mm (0.7 or 0.9 inches) thicknesses.
A common mistake is using the shelf span without intermediate support, which leads to sagging. If you know the wardrobe width: observe the following rule of thumb – from 60 cm (24 inches) width upwards, stability becomes critical with standard shelves.
In summary: Ikea does not have an official "extra sturdy" Pax shelf, but there are various possibilities to reinforce shelves through accessories or third-party products.
I hope this helps!
I hope this helps!
Manabidin, you’re asking about particularly sturdy shelves for the Ikea Pax system.
I have thoroughly tested this myself since I fitted a custom wardrobe with heavy items.
The standard Pax shelves (particleboard, 16 mm [0.63 inches] thick) are designed for light to medium loads. The maximum load capacity is about 15–20 kg [33–44 lbs] per shelf, depending on the width. Here are some details and tips:
- Material: Standard shelves are often made of melamine-coated particleboard, which tends to sag in the middle under heavy loads. MDF shelves with a thickness of 18 mm [0.71 inches] offer more stability.
- Reinforcement: Adding stiffening battens underneath the shelf (wood or metal) can be done by yourself and significantly increases load capacity.
- Number of supports: Use more shelf supports per shelf, especially for wide units (over 60 cm [24 inches]).
- Width: For shelves wider than 80 cm [31 inches], it’s worth installing a second center support or continuous reinforcement.
Do you have the exact dimensions of your Pax frame? For very wide compartments, Ikea doesn’t offer officially stronger shelves, but I have found special heavy-duty shelves with matching dimensions at cabinetmaking suppliers or hardware stores.
If you like, we can also review your requirements together and discuss suitable solutions.
manabidin23 Oct 2023 15:42Nabla64 schrieb:
Ikea occasionally sells reinforced shelves, for example made from thicker materials or with metal reinforcements – however, these are not always available nationwide or permanently in their range.Thanks for the tip! Do you remember which types or item numbers those were?
Gafiel schrieb:
Do you have the exact measurements of your Pax? For very wide compartments, Ikea does not offer official stronger shelves, but I have found special heavy-duty shelves with suitable dimensions at a cabinetmaker’s supply store or hardware store.I have 100 cm (39 inches) wide compartments in several sections, which is quite wide. A sturdy solution would definitely be important.
Gafiel, which thickness and materials would you specifically recommend?
Would a 22 mm (0.87 inch) thick MDF shelf from Ikea help, or would it be better to reinforce it yourself with metal brackets or similar?
Looking forward to your advice!
For reference:
- The standard shelves in the Pax system are made from untreated melamine-coated particleboard with a thickness of 16 mm (0.63 inches).
- Load capacity is approximately 15 kg (33 lbs) per shelf, depending on the width.
- For shelf widths of 60 cm (24 inches) and above, sagging becomes clearly visible.
For 100 cm (39 inches) wide compartments, like those owned by manabidin, I recommend:
- Replacement with MDF or plywood boards at least 18 to 22 mm (0.7 to 0.87 inches) thick
- Additional central supports or metal brackets to distribute the load
Ikea does not offer any special “extra sturdy” shelves in the Pax range.
The best long-term solution is an improved DIY construction using stronger materials and supports.
This way, functionality is maintained without compromising the appearance.
It may also be worth considering Ikea’s load ratings for the shelves, which are often underestimated.
