ᐅ Are there Ikea Pax wardrobes available with options suitable for tight sloped ceilings?
Created on: 29 Mar 2024 08:37
DOBLA
DOBLA
29 Mar 2024 08:37
I am planning to install an IKEA Pax wardrobe in my bedroom, which has a sloped ceiling. My question is quite specific: Does IKEA offer any Pax models or variations specifically designed for tight sloped ceilings?
I don’t just mean the standard Pax wardrobe systems that you can cut or modify yourself, but whether IKEA officially provides alternative structures, angled attachments, or special components that adapt to such sloped ceilings.
If not, I’m also interested in how others have solved this, especially when there is limited space for adjustments and the slope is really close. Are there suitable interior fittings or customization options within the Pax system that make this easier?
I appreciate all tips, experiences, and advice!
tutan
29 Mar 2024 09:05
DOBLA schrieb:
Are there any IKEA PAX models or variants specifically designed for tight sloped ceilings?
The straightforward answer: Unfortunately, IKEA does not officially offer any PAX variants specifically made for sloped ceilings. 😕
But hey, that doesn’t mean it can’t still work! Many people customize their PAX wardrobes themselves – using cut-to-size panels, tailored interior fittings, and angled finishes through DIY solutions.
A little tip: Use adjustable shelves and pull-out organizers that are easy to modify. With sloped ceilings, a bit of DIY effort is often the most cost-effective approach. And don’t worry, a bit of hands-on work can be fun too!
Maria35
29 Mar 2024 11:28
DOBLA schrieb:
Are there any IKEA Pax models or versions specifically designed for tight attic slopes?
IKEA does not offer any Pax wardrobe systems that are specifically designed for sloped ceilings. The standard frames are modular but always rectangular.
For tight attic slopes, customers usually use the following approaches:
- Cutting the back panels and side trims with a circular saw or jigsaw.
- Using angled plinths or spacers to compensate for height and angle differences.
- Flexible interior fittings, such as adjustable shelves or components that can be mounted variably.
The advantage is that Pax is fairly adaptable, but custom-made solutions are not offered by IKEA. For a professional fit, a custom carpentry solution should be considered.
I also recommend measuring the exact dimensions of the slope and ceiling height on site digitally to avoid fitting errors.
LOGEMIN
30 Mar 2024 14:14
A brief guide on how to handle a standard IKEA Pax wardrobe with sloped ceilings:
1. Measuring: Accurately measure the height and angle of the sloped ceiling.
2. Frame selection: Choose narrower widths for the Pax wardrobe (e.g., 50cm (20 inches)), as these are easier to adapt to slopes.
3. Cutting: You can use an affordable jigsaw to adjust the back and side panels to fit the slope. Make sure to maintain stability.
4. Interior fittings: Use adjustable shelves and flexible hanging rails – these make efficient use of space in tight areas.
5. Fascia panels: For visible sloped areas, angled fascia panels or shelves that you can customize are useful.
6. Assembly: Assemble the wardrobe at full height first, then trim the back panel and fascia panels to fit.
Common mistake: Trying to install the wardrobe exactly to the slope without any adjustments afterward. Your goal should always be a combination of precise fitting and flexibility.
A highly recommended option is also to use additional adjustable feet or wedges for secure positioning.
nubar
31 Mar 2024 10:52
DOBLA schrieb:
Are there any IKEA Pax models or versions specifically designed for tight sloped ceilings?
There are no official Pax versions designed specifically for sloped ceilings.
My advice:
- Carefully measure the room size, including the slope, in advance
- Plan for custom adjustments, either DIY or by a carpenter
- The IKEA Pax system offers a good modular base, but the final shape for sloped ceilings requires individual customization
Additionally, I recommend carefully considering the door types (sliding vs. hinged), as sliding doors are often less suitable for sloped ceilings.
