ᐅ Are there any Ikea Brimnes furniture pieces with improved airflow?
Created on: 26 Jul 2020 08:37
Marinari54
Marinari54
26 Jul 2020 08:37
I am currently looking into selecting furniture from the Ikea Brimnes series and have an important question that has been on my mind: Are there models or variations within the Brimnes range that offer better air circulation than others?
Specifically, I am wondering if there are any structural differences in ventilation in wardrobes or dressers from this series, because I am concerned that poor air circulation could lead to moisture problems or unpleasant odors.
So far, I have only seen standard models, some of which have closed panels without visible ventilation features. Are there perhaps other versions or alternative designs in the Brimnes lineup that address this issue, or is this generally not a concern with this furniture?
I would really appreciate any experiences or detailed information, especially from those who use a version with better air circulation in everyday life. Thanks in advance!
Raymond
26 Jul 2020 10:42
Hello Marinari54,
Regarding your question: "Are there models or variants within the Brimnes furniture series that offer better air circulation than others?" – generally, it must be said that the Brimnes series from Ikea is primarily designed for functional storage solutions and modern aesthetics, rather than specific ventilation features.
Most pieces in the series have closed fronts and side panels, which significantly limit air circulation. However, there are some models, such as dressers or cabinets with open back panels or slotted openings at the rear. These are not explicitly labeled as "ventilation-optimized" but can help air to flow through the furniture.
If better air circulation is a priority for you, you can specifically look out for model details like open or perforated back panels or possibly recessed handles that minimally contribute to air movement. Still, this won’t be comparable to specialized furniture intentionally designed with ventilation elements.
If moisture issues are a concern, I would also recommend checking the indoor climate and considering options such as wall vents or electric dehumidifiers, as the furniture alone usually won’t solve this.
In summary: No, there are no specific variants within the Brimnes series designed particularly for enhanced air circulation, but some models offer slightly better airflow through open back panels compared to fully closed pieces.
Far34
26 Jul 2020 11:56
Marinari54, there is simply no better ventilation option for Brimnes.
As an alternative, get furniture with glass or perforated back panels or create ventilation slots yourself.
Otherwise, regular airing out is the only effective solution.
lise56
27 Jul 2020 14:21
Raymond schrieb:
So if your main goal is better air circulation, you can specifically look for model details in Brimnes like open or perforated back panels or maybe handle recesses that slightly contribute to air movement.
To what extent are some of the back panels in Brimnes actually open or perforated? As far as I know, most back panels are standard MDF boards that are fully closed.
I question this because an “open back panel” usually applies to shelves or display cabinets, not to closed wardrobes like those in the Ikea Brimnes series.
The suggestion of handle recesses as a ventilation feature seems too weak to actually ensure noticeable air circulation.
If air circulation is really important, in my view, you should either specifically look for furniture designed with ventilation holes or open compartments, or install an additional solution, such as drilling extra ventilation grills into the back panels.
I would approach this from a practical perspective and consider whether the furniture can be technically modified if no ventilation is originally intended.
Has anyone had experience converting or modifying Brimnes furniture to improve air exchange?
