ᐅ Are there heat-resistant furniture films to prevent fading on KALLAX units?
Created on: 4 Jul 2023 08:23
Nibau34
Good morning everyone,
I have the following question: Are there heat-resistant furniture films that specifically protect against fading on a KALLAX shelf from IKEA? I’m looking for films that maintain their color and texture even when exposed to sunlight and higher temperatures, without fading or getting damaged quickly. I want to protect my KALLAX in the living room in a fairly bright spot without completely changing the surface or applying a complicated paint job. Does anyone have experience with such heat-resistant films that also look good? Thanks in advance!
Hello Nibau34,
I would like to address your question in more detail, as choosing and evaluating the effectiveness of heat-resistant and UV-resistant furniture films is not straightforward.
Primarily, adhesive films for furniture are usually PVC-based, often with additional UV stabilization or lamination. The heat resistance of these films is generally up to 80°C (176°F), which seems sufficient for indoor conditions, but direct sunlight on black or dark films can cause significantly higher surface temperatures.
Therefore, I recommend the following steps:
1. Material selection: Look for films with explicit UV and heat protection, often labeled as ‘UV-stabilized’ and ‘resistant to thermal effects.’ Manufacturers like 3M or Orafol offer such films for automotive or exterior applications.
2. Application: Apply precisely to avoid wrinkles and air bubbles, which can reduce durability.
3. Environmental management: Use window shading to reduce overall exposure.
4. Alternative: Consider whether painted or sealed surfaces might be more durable than films applied to KALLAX material.
I’m curious: Is your shelf placed directly against south-facing windows? And how many hours per day does it receive strong direct sunlight?
PLOMA schrieb:
I’m curious: Is your shelf located directly next to south-facing windows? And how many hours per day is it exposed to strong direct sunlight?Thank you for the detailed answer! Yes, the shelf is placed near a large south-facing window, with sunlight shining directly on the side surface from morning until midday, about 3 to 4 hours daily. This is also why I am looking for durable films, as fading is especially noticeable on the outer edge.
elgla schrieb:
I feel the same way. A few months ago, I tried covering my KALLAX near the window with a film – unfortunately, the color still faded over time despite UV protection.I’ve experienced that too. It’s really frustrating when you think you’re protecting the furniture, but it still ends up fading. I suspect that both the quality of the films and the application process make a big difference.
Maybe Nibau34 can share whether they rely on specific brands or if they found a supplier with verified technical data.
Nibau34 schrieb:
The shelf is located near a large south-facing window, and direct sunlight hits the side surface from morning until midday, about 3 to 4 hours daily.This puts a lot of stress on films. My recommendation: additionally, window films with high UV protection or a specialized sunshade roller blind can be installed relatively inexpensively. This will significantly reduce the surface temperature of the furniture and extend the lifespan of the film.
I installed heat-resistant films myself on a Kallax unit. It is important to choose films from the automotive sector, as they often have good UV and heat protection properties. After one year of intense sun exposure, I can say that fading is significantly reduced but not completely prevented. However, the Kallax material itself still fades somewhat. Regular cleaning also helps.
kautra schrieb:
Fading is greatly reduced but not completely prevented.That’s exactly the point. There is no 100% protection against strong sunlight exposure on furniture surfaces with films.
