ᐅ Are there furniture designs that are better suited than the IKEA Brimnes series?
Created on: 10 Sep 2020 08:27
Liani
Are there furniture constructions that are better suited than the IKEA Brimnes?
I am currently researching a new wardrobe system, focusing on stability, ease of assembly, and good value for money. The IKEA Brimnes is often recommended because of its design and price, but I wonder if there are other furniture constructions or product systems that are actually better in terms of material quality, durability, and overall functionality.
I am particularly interested in comparisons regarding joinery techniques (such as dowels, biscuits, cam locks), the load-bearing capacity of the construction for daily use, and factors like simple or flexible expandability.
Do you have experience or recommendations beyond the IKEA Brimnes? Which alternatives tend to be more reliable or offer a better overall concept?
Leonardteo
11 Sep 2020 10:18
The Brimnes series is reasonable for the price, but for heavy use or greater loads, I recommend furniture with the following features:
- Carcass made of at least 18 mm (0.7 inches) plywood or veneered MDF panels
- Joinery using biscuits or Minifix systems for stable corner connections
- Reinforced back panels made of 5 mm (0.2 inches) HDF boards to increase carcass rigidity
These features significantly improve durability and ease of assembly compared to the Brimnes.
If modular expandability is important, cabinet systems with locking or slot systems are also suitable – these are often designed more professionally.
TYRELL
12 Sep 2020 16:45
Liani schrieb:
Are there furniture designs that are better suited than IKEA Brimnes?
A nuanced answer requires defining what “better” means. Does it refer to stability, assembly, design, value for money, or sustainability?
Technically, the Brimnes is more of a compromise between low-cost production and easy assembly. The used 16 mm (5/8 inch) particleboard with foil coating is only moderately dimensionally stable and does not offer particularly high load capacity, especially on the back panel. The cam locks and dowels as fasteners are proven, but have limitations compared to biscuits or glued tongue-and-groove joints.
For those who value durable construction, furniture with:
- Plywood carcasses (15–18 mm (5/8–3/4 inch))
- Real wood edges or solid plastic edging
- Joining techniques with biscuits (dovetail joints in solid wood are even more elaborate)
- Solid wood frames or reinforcements
- High-quality back panels made of HDF or thick MDF
should be considered.
It becomes problematic with cheaper alternatives to Brimnes that may appear “sturdier” but are also made from particleboard and only look higher quality; this is often just superficial.
If the focus is on flexibility and inexpensive assembly, Brimnes remains competitive. However, in terms of quality and lifespan, many other manufacturers, including bespoke carpentry, offer better options.
bulanau
13 Sep 2020 09:02
I would like to summarize the discussion and provide practical tips on what to look for when searching for better alternatives to the IKEA Brimnes:
1. Material choice:
- Particleboard is inexpensive but less durable. Plywood or MDF is more stable.
- Solid wood is very robust but also more expensive and heavier.
2. Joining techniques:
- Biscuits (lamellos) offer greater stability and prevent breakage under heavy loads.
- Cam lock fasteners are convenient but not as strong as biscuits or traditional wood joints.
3. Back panel:
- Thicker back panels made of HDF or MDF significantly increase the cabinet’s rigidity.
4. Edges:
- Real wood edges or high-quality plastic edges provide better protection than veneer finishes.
5. Ease of assembly:
- Snap-fit systems or well-designed construction principles make assembly and later modifications easier.
My tip: If you want flexible and durable storage, choose furniture that combines plywood panels with biscuits and sturdy back panels. This results in a construction that is noticeably more stable and durable in everyday use than the Brimnes, without immediately requiring expensive custom woodworking.
