ᐅ Are there environmentally friendly paints or finishes suitable for Ikea Brimnes furniture?
Created on: 14 Jul 2020 08:37
Barnau
Barnau
14 Jul 2020 08:37
Are there environmentally friendly paints for Ikea Brimnes?
I want to repaint my Ikea Brimnes cabinet but would like to do it as eco-consciously as possible. I’m interested in paints or coatings that are low in harmful substances, ideally water-based or carrying other ecological certifications. Maybe you have experience with specific products that adhere well to the particleboard-like surfaces of the Brimnes furniture without the paint peeling off quickly or developing unattractive cracks.
Which paints can you recommend that offer good coverage while containing as few harmful VOCs (volatile organic compounds) as possible? Perhaps you also know about special methods for surface preparation or suitable primers that improve the durability of environmentally friendly paints.
I would greatly appreciate any suggestions regarding brands, possible sources, and application tips.
trevor
14 Jul 2020 09:05
Hi Barnau, great question! Environmentally friendly and Ikea can be a bit tricky sometimes because furniture like Brimnes often uses melamine-coated particleboard, which doesn’t always accept paint easily.
I’ve had good results with water-based acrylic paints. They are usually low odor, dry quickly, and have significantly fewer VOCs than traditional solvent-based paints.
A little tip: lightly sand the surface first (very fine sandpaper) to help the paint adhere better. After that, you can apply a suitable water-based primer to even out the surface’s absorbency. This helps prevent bubbles or cracking.
And yes: truly eco-friendly paints tend to be more expensive, but they release fewer harmful substances into your living space—hardly more sustainable than that.
The only question left is whether you prefer a matte or glossy finish—most environmentally friendly paints are available in both options.
cassandra
15 Jul 2020 11:21
Environmentally friendly paints for Ikea Brimnes do exist in principle, but due to the melamine-coated chipboard, proper preparation is necessary.
I recommend the following approach:
- Thoroughly clean and lightly sand the surface before painting to improve adhesion.
- Primarily use water-based acrylic paints with environmental certifications such as Blue Angel or EU Flower. These are characterized by low VOC emissions.
- Some brands, like "Clou Vega Weißlack Aqua," offer low-emission paints specifically suitable for furniture.
- An intermediate sanding after the first coat increases durability and ensures an even surface.
Please note that even environmentally friendly paints may have certain weaknesses regarding scratch resistance. Therefore, using a good primer in combination is essential.
trevor
16 Jul 2020 17:43
cassandra schrieb:
Environmentally friendly paints for Ikea Brimnes do exist in principle, but they require proper preparation due to the melamine-coated particleboard.
Exactly!
I’d like to add: If you’re up for a small DIY adventure, you might also consider water-based varnishes with natural resins. They are a bit more expensive but definitely better for the environment.
And again: Fine sanding is often underestimated. Better to sand lightly but thoroughly, otherwise you’ll end up with a peeling surface.
Other than that, it’s really fun to give the Brimnes a fresh new look without using harsh chemicals.
