I recently purchased a Malm furniture piece from IKEA and would like to care for it in the most environmentally friendly way possible. I am interested in whether there are sustainable and effective care tips to keep the furniture in good condition for a long time without relying on environmentally harmful products. Specifically, I am looking for cleaning agents that do not contain harsh chemicals, and possibly homemade solutions or natural substances that protect the surface while still cleaning thoroughly.
Does anyone have experience or recommendations on how to maintain Malm furniture in an eco-friendly way? Advice on dosages or application times would also be helpful, as I want to avoid damaging the surfaces with too much liquid or improper products.
I would appreciate any tips and discussion!
Rashadmeo5 Mar 2023 19:03kenrick3 schrieb:
I'm specifically interested in cleaning agents that do not contain harsh chemicals, and possibly homemade solutions or natural substances that protect the surface while still cleaning thoroughly.It's great that you want to focus on sustainable care! 🙂 I recommend using a mixture of lukewarm water and a bit of vinegar essence (dilution 1:10) for Malm furniture. Vinegar is not only eco-friendly but also kills bacteria and is very affordable!
Important: Never apply the solution undiluted. Instead, put it on a microfiber cloth first and then wipe the furniture. This helps avoid excess moisture that could damage the wood. Afterwards, wipe again with a dry cloth.
This method works really well for me, and the best part is: you no longer have chemical issues in your home! Good luck trying it out!
Rashadmeo schrieb:
I can recommend using a mixture of lukewarm water and some vinegar essence (dilution 1:10) for Malm furniture.Although vinegar essence is a natural and eco-friendly cleaner, caution is advised with painted or veneered surfaces, as the acid can damage the protective layer with frequent use.
For Malm furniture, I suggest the following care method:
1. Remove dust using a dry or slightly damp microfiber cloth.
2. For cleaning: use a detergent based on natural surfactants (for example, a very diluted eco-friendly dishwashing liquid).
3. Wipe with gentle movements and as little water as possible to prevent swelling of the chipboard.
4. Immediately dry the furniture with a dry cloth after wiping.
Additionally, a special wax-based care product can be used occasionally to protect and nourish the wood.
It is best to avoid aggressive or acidic cleaners, as Malm furniture is usually made of chipboard with a thin coating.
To delve deeper into the topic:
Malm furniture is generally made from particleboard with a melamine resin coating, sometimes veneered. This means the surface is durable but can be damaged by excessive moisture or harsh cleaners.
My recommendation for environmentally friendly care is a combination of:
- Dry dusting with a dust cloth or microfiber cloth (recommended once daily to prevent dirt particles)
- Slightly dampened cloth with lukewarm water when there are stains
- For stubborn spots: a solution with organic dish soap (e.g., one drop in 5 liters (1.3 gallons) of water), applying only light pressure
- Never use heavily abrasive sponges, as they can scratch the surface
An important point: moisture should never be left standing on the surface. Therefore, always wipe dry immediately after cleaning.
Additionally, the furniture can be treated with biodegradable care oils designed for melamine to protect the surface and reduce minor wear marks. It is important to choose products without solvents.
Finally, a tip: it is best to avoid common furniture polishes that often contain silicones or solvents, as these can damage the surface over time and cause environmental issues.
Do you need tips on specific products or would you like to describe your usage in more detail?
Gafiel schrieb:
Do you still need tips on specific products or would you like to describe your usage in more detail?Thank you for the detailed post! I mainly use the Malm furniture as a chest of drawers in the bedroom, so dust and occasional stains from clothing are the main issues. I will pay attention to cleaning with dish soap, and I’ve also tried wiping it dry immediately because I want to avoid any unsightly water spots.
I’m curious whether you know of an eco-friendly method to restore small scratches or dull areas? This is often a problem with melamine surfaces, as they tend to look dull and show minor damage after prolonged use.
Are there sustainable solutions that can be applied at home, or is a professional product generally needed in this case?
