Hello everyone, I own several IKEA Billy bookcases, which I use as room dividers and storage. However, one of the larger units tends to wobble noticeably when it is loaded more heavily, for example with books. Are there any proven DIY solutions or simple tricks to significantly improve the stability of a Billy bookcase without resorting to professional methods or rebuilding it? The main goal is a practical reinforcement that can be done with household tools or minimal effort.
I reinforced my Billy with these ratchet straps from the hardware store – basically stretched across the back panel. It worked great and it doesn’t wobble anymore. They’re affordable, easy to install, and barely noticeable. 😉
Oh, and a small tip: always use small felt pads or non-slip pads on the floor, as this significantly improves stability.
With some basic DIY skills, you can even build an angled frame from wooden slats that is screwed from the inside into the corner walls. This provides additional rigidity with minimal effort.
PERON schrieb:– a creative idea that also adds visual interest. However, the loops should be checked every few years for tension in case anything loosens.
Tension straps reinforced from the hardware store
V
vincent4617 Aug 2020 13:21I completely understand how frustrating it is when a shelf wobbles, especially if you use it often for books or heavy items. Maybe you could also try securing the shelf with the wall mounting kit from IKEA? Although it’s not purely DIY, it’s a simple and cost-effective addition.
Sometimes a little patience tightening the connectors helps, as they can loosen under load.
I had similar issues and chose simple wooden shims under the feet to compensate for unevenness in the floor. This made my shelf stand much more stable.
Additionally, I installed small wooden dowels on the inside edges to reinforce the joints. This helps the shelf hold together better even under heavy load.
RETRAVIS schrieb:
Cut a thin plywood or MDF board to shelf size Thanks for the tip, that sounds like a really practical solution.I will give it a try and then attach the metal brackets to the inner frame as described, making sure to secure everything well with screws.
vincent46 schrieb:
Secure the shelf with the wall mounting kit I haven’t consistently used that so far, but I will add it now, since extra wall support definitely makes sense.Overall, thanks to everyone! Your suggestions are very helpful, and I can now make a clear plan for my project.
