ᐅ Are there any DIY ideas for refurbishing IKEA Hemnes dressers?
Created on: 16 Oct 2017 09:23
jaques
jaques
16 Oct 2017 09:23
Good morning everyone,
I am considering customizing my IKEA Hemnes dressers to make them more unique, as I find the classic design a bit too plain and monotonous now. Are there any DIY ideas or good guides here in the forum on how to effectively transform these dressers—whether through creative painting, replacing the handles, changing materials, or even adding built-in features? I’m especially interested in long-lasting and practical solutions that can be achieved with a reasonable amount of effort. Maybe someone has personal experience with which techniques work best and what should be avoided. Thanks for your tips and suggestions!
Dwight49
16 Oct 2017 11:18
The Hemnes dresser is well suited for various DIY projects due to its sturdy wooden construction and smooth surfaces.
The following approaches have proven effective:
- Sanding and repainting with chalk paint or acrylic paint for a modern or vintage finish
- Replacing the standard handles with metal, leather, or brass handles for an enhanced look
- Adding wallpaper or fabric inserts behind glass panels (for glass doors) or as drawer decoration
- Be cautious when using excessive moisture or harsh solvents, as the veneer can be damaged
Careful surface preparation is essential to ensure long-lasting paint adhesion. I also recommend applying a sealant after painting to reduce scratches and wear.
trevor
16 Oct 2017 13:07
Dwight49 schrieb:
The Hemnes dresser is very suitable for some DIY projects due to its sturdy wooden construction and smooth surfaces.
Exactly, Dwight! I once experimented with a mix of water-based and chalk paint – now the dresser looks like it’s got a few more years on it, which really adds character.
Of course, you can keep it clean and modern, but a bit of a distressed look really brings it to life. Especially if you add some cool handles, I say: Voilà – design classic 2.0!
If you like, you can also use small wall decals or stencils, so it’s not just paint but shows a bit of personality. DIY with a fun factor – that’s how upgrading furniture becomes really enjoyable!
U
Ulrichta
17 Oct 2017 08:44
If you are new to furniture remodeling, here are some basic tips for the Hemnes dresser:
- Before painting, make sure to sand the surface, ideally with 120-grit sandpaper, to ensure proper adhesion of the paint.
- Old handles can often be removed easily using a simple Allen wrench; when installing new handles, make sure the drill holes match exactly.
- For chalk paints, it is recommended to apply a wax layer or a matte sealant after painting to enhance durability.
- For fabric inserts, you can line the inside of drawers with double-sided tape, but be cautious of moisture.
I encourage everyone to try small experiments, but always start with tests on inconspicuous areas. If you have questions about any steps, I’m happy to help!
Sepele
17 Oct 2017 11:52
To customize the Hemnes dresser in a truly unique and professional way, I recommend the following steps as a small project:
1. Empty the dresser and place protective coverings.
2. Remove all handle fittings completely and, if necessary, fill holes with wood filler and sand them smooth.
3. Sand the entire surface lightly (using 120 to 180 grit sandpaper).
4. Apply a primer suitable for the final paint color (especially important for lighter shades).
5. Apply paint in thin layers, sanding lightly between coats.
6. After drying, seal the surface with either polyurethane varnish or furniture wax, depending on the desired finish.
7. Replace or restore the handles according to your preference.
Common mistakes include insufficient sanding or skipping the primer, which can lead to issues like peeling later on. It is also important to allow adequate drying time to ensure a smooth and durable finish.
