I am currently looking into whether there are extensive DIY guides for Ikea Hemnes furniture that go beyond basic assembly and also cover modifications and customizations. Specifically, I am interested in whether anyone knows of detailed instructions or has created their own that demonstrate how to convert or personalize Hemnes furniture for more specific purposes. I am not just looking for simple assembly tips, but rather creative expansions, such as altering dimensions, adding extra features, or stylistic adjustments (painting, changing the surface finish, etc.).
Perhaps someone knows of resources or has personal experience? Thank you in advance for your feedback!
faso31 schrieb:
Some instructions sound good but overlook the material behavior or the load that modifications can cause.That is correct and an important point. Many DIY guides often do not address the structural aspects. For Hemnes furniture, a modification is only advisable if the original materials are not overloaded. When altering connection points, stable replacement fittings or reinforcements should also be considered.
I have personally modified Hemnes dressers by changing the paint, installing new handles, and adding drawers with soft-close mechanisms. The best guides I found were from hobby DIYers who document their projects step-by-step.
It is important to take your time and not see the instructions as rigid rules, but rather as inspiration. DIY projects thrive on experimentation – every tutorial provides a great starting point!
RENMA schrieb:
I recommend a targeted search for DIY projects related to the Hemnes series, focusing on "customizing" or "refurbishing."Thanks for the tip, that sounds very helpful. Could you be more specific about where such communities are typically found? I would like to avoid having to sift through too many irrelevant results.
AUSTINREN28 Jun 2021 08:23Most platforms with user forums focused on furniture restoration and DIY also include sections dedicated to Ikea furniture. There, you will often find threads where users share projects and instructions—sometimes specifically related to Hemnes.
In addition, some DIY magazines and construction guides offer special articles on modifying mass-produced furniture. It is also recommended to search for PDF instructions or tutorials using keywords like "Ikea Hemnes conversion DIY" for better results.
Avoid platforms with commercial interests, as many of the instructions found there tend to be incomplete or poorly developed.
When I spent too much time searching and then came across DIY guides for Hemnes, the best approach was usually to give my own ideas some freedom and then start with simple basics like sanding and painting.
You don’t always need a detailed master plan from the internet to achieve a cool transformation with Hemnes. This way, crafting is more enjoyable!
