ᐅ Are there any dimensional tolerances to consider with Ikea PLATSA units?
Created on: 16 Feb 2022 08:12
Klaleondre
Hello everyone, I am planning to install an Ikea Platsa wardrobe system and have come across a question during the planning process: Are there any dimensional tolerances to consider with Ikea PLATSA? Specifically, I want to know if the listed measurements for the individual modules and cabinet components need to be followed exactly, or if there are manufacturing variations or allowances that should be taken into account during measurement planning and installation. I want to avoid unpleasant surprises later on, for example, if a shelf or module does not fit precisely, especially when planning built-in or niche solutions. Are there any practical experiences, technical notes, or official information regarding the dimensional tolerances of PLATSA? Thanks in advance for your insights!
JAMESONB41
16 Feb 2022 13:47
The connectors and anchors used allow for slight deviations in the components. This makes it possible to compensate for small measurement differences effectively. The important thing is that the measurements are realistically taken on site so that the planning can be adjusted accordingly.
sarlo
16 Feb 2022 15:23
In addition to the previous posts, I would like to point out that Ikea also recommends checking the dimensions of the parts upon delivery before assembly. Returns or exchanges can be made if there are significant deviations. Furthermore, the assembly instructions are very helpful because they often include information about the tolerances considered during construction. Therefore, it is advisable to systematically measure and compare the parts before starting.
Benge5
17 Feb 2022 08:44
In practice, the dimensional tolerances for Ikea Platsa are approximately +/- 2 mm (+/- 0.08 inches). This information is based on our own measurements and the analysis of customer reports. Usually, this tolerance allows for easy installation as long as the installation situation offers some flexibility. Problems arise with longer cabinets that need to fit tightly between walls without any clearance. In such cases, these tolerances can make installation difficult or even impossible.
V
Vinlen
17 Feb 2022 10:11
theota schrieb:
I find the idea a bit naive anyway – wood materials expand due to humidity, installation errors, material irregularities – all factors that cannot be controlled.
This is a very important point you raise. Furniture should never be considered in isolation – the environmental conditions and the method of installation significantly affect the overall outcome and the fitting accuracy. Assembling components too tightly can cause more harm than good.
giabau
17 Feb 2022 11:38
Klaleondre schrieb:
Are there any dimensional tolerances to consider with Ikea PLATSA? Specifically, I’m interested in whether the stated measurements for the individual modules and cabinet components must be followed exactly, or if there is some allowance or variation in manufacturing that should be taken into account during planning and assembly.
To return to your main question: No, you don’t have to adhere strictly to the nominal dimensions since such tolerances do exist. The design should accommodate these variations. When installing in niches, it’s advisable to leave a clearance of about 1–2 mm (0.04–0.08 inches) all around to avoid issues later on.
sarlo
18 Feb 2022 09:07
In conclusion, it should be noted that Ikea deliberately offers PLATSA as a flexible system that is modularly expandable and adaptable. The dimensional tolerances are part of the overall concept to accommodate different space conditions. Therefore, the components were designed to fit well together even with slight deviations. Anyone with some experience and a realistic assessment of the situation can avoid problems effectively.
