ᐅ Are there differences in quality between different batches of Billy?
Created on: 17 Jan 2023 08:34
Adamta
Hello everyone, I’ve recently been wondering whether there are really differences in quality between different Billy production batches. I’m not just referring to slight color variations, but also the workmanship, material thickness, or shelf stability. There are occasional reports suggesting that newer or older batches might vary more in quality. I’m particularly interested in whether anyone has reliable observations or experience regarding different production periods and their quality. Are there any systematic changes in manufacturing to be aware of when looking to purchase a high-quality Billy shelf? I look forward to your informed opinions and experiences!
joro10
18 Jan 2023 08:21
Basically, I would focus more on the overall stability, as the subtle differences in materials are often insignificant for everyday use. A surface that looks cheaper does not automatically mean lower quality. If the shelf wobbles, it is usually due to improper assembly or the base.
draleo
18 Jan 2023 09:37
Adamta schrieb:
I am particularly interested in whether anyone has reliable observations or experience regarding different production periods and their quality.
After reviewing several reports and tests, it can be said that batch variations do exist but generally do not lead to significant quality loss. These are mostly moderate fluctuations in material thickness and manufacturing tolerances. Such variations are typical in mass production.
There is some indication that batches produced before 2015 tend to have greater material thickness, while newer batches are somewhat slimmer. This has a slight effect under load, for example when heavily loaded. However, stability usually only suffers if the shelving is not assembled correctly or subjected to excessive weight.
Conclusion: For maximum stability, it is advisable to look for batches with greater material thickness, but the difference is not drastic. Production codes can help draw more precise conclusions.
If desired, I can provide instructions on how to decode production codes and compare them meaningfully.
Dilen
18 Jan 2023 11:44
draleo schrieb:
There are indications that batches from production years before 2015 tend to have thicker material, while more recent batches are manufactured somewhat slimmer.
I will elaborate on this a bit:
IKEA’s manufacturing process uses internal batch codes, usually consisting of the date (format yyyy-mm-dd) and an internal production number. You can often find these as stickers on the side of the box or stamped on individual shelves. For Billy shelves, the code might be on the bottom shelf or behind the back panels.
To verify quality, it is advisable to compare several batches in a row – you can even roughly assess the density of particleboard or MDF at home using a caliper.
Storage and transport conditions can also unfortunately affect the final quality. Boards can warp due to moisture or edges may fray.
Do you have a specific batch code you would like to compare? I might then be able to give you a more precise assessment of its classification.
