ᐅ Are there design ideas combining Ikea Hemnes furniture and LED lighting?
Created on: 7 Apr 2021 18:37
Teti63
Teti63
7 Apr 2021 18:37
Any design ideas for Ikea Hemnes and LEDs?
I’m currently exploring ways to enhance the popular Ikea Hemnes series with LED lighting elements to add atmosphere and functionality to a room. I’m particularly interested if anyone has found creative or practical solutions that combine Hemnes furniture pieces like sideboards, beds, or display cabinets with LED strips or spotlights—details about implementation, recommended LED types (e.g., RGB, warm white), and possible power supply options are very welcome.
Additionally, I’d appreciate tips on how to integrate the lighting in a way that is both visually appealing and safe, as well as easy to handle. Thanks in advance for your opinions and experiences!
Devin
7 Apr 2021 19:02
I installed LEDs under the Hemnes sideboard to provide subtle indirect lighting. I use flexible LED strips in warm white, attached simply with double-sided tape and connected to a power supply.
benfa
7 Apr 2021 20:41
Interesting question. However, when combining Ikea Hemnes furniture with LED lighting, it is important to consider not only the appearance but also electrical safety and durability. Many LED strips from hardware stores provide a lot of light at a low price but often lack sufficient cooling or quality assurance.
If you plan to integrate RGB LEDs, ask yourself whether the control system truly fits your intended use, or if, for example, a simple warm white lighting solution would offer better performance and require less maintenance. Visible cables should also be carefully planned – with Hemnes furniture featuring a lot of wood and exposed edges, cable management can quickly look untidy.
Laukau5
8 Apr 2021 09:29
Regarding design ideas with Ikea Hemnes and LEDs, I have compiled the following detailed experience:
1. Installation and LED selection: For Hemnes furniture, which is mainly made of solid wood or veneered material, I recommend flexible 12V LED strips with at least 120 LEDs per meter. These provide even light distribution and are relatively easy to install. It is advisable to choose warm color temperatures (2700 to 3000 Kelvin) as they highlight the wood best.
2. Mounting: Double-sided tape is usually sufficient for smooth surfaces, but for wood, I suggest additionally using small aluminum profiles or clips to ensure longer durability.
3. Power supply and wiring: A power supply with sufficient capacity (e.g., 12V/2A for a 5m (16 ft) LED strip) is recommended. It is best to place the wiring neatly inside cable channels or behind the furniture to avoid messy cables.
4. Integration of special lighting areas: LED strips work particularly well inside the glass display cabinets of the Hemnes series. Spots or LED bands can be installed on the inside to effectively showcase the decor.
5. Pitfalls: Make sure the LEDs are not blocked by the drawer base or other surfaces through the wood. Also, connectors on the strips can sometimes be fragile. A secure and easily accessible installation is advisable in case you need to replace LEDs.
Do you have mostly open furniture or closed cabinets in your case? That would slightly influence the approach.
Sinan-meo
8 Apr 2021 10:14
A tip for implementation: To achieve glare-free LED lighting in the Hemnes cabinet or sideboard, frosted diffuser covers combined with LED strips are helpful. This prevents harsh light edges and the appearance of bright spots, which is especially more pleasant with clear-coated wood.
Additionally, the power supply should be through a Class 2 power adapter to minimize the risk of short circuits and electrical accidents.
benfa
8 Apr 2021 11:07
Laukau5 schrieb:
LED strips work especially well in the glass display cabinets of the Hemnes series. Spots or LED strips can be installed inside to effectively highlight the décor.
You raise an important point. However, I see a potential issue here: Hemnes glass display cabinets often have relatively thin glass shelves and quite open edges. It would be necessary to carefully check whether the LED temperatures and possible heat generation could affect the wood or glass if the strips are left on continuously. In that case, a control system with a timer or motion sensor might be a useful addition to minimize energy consumption and heat build-up.
