ᐅ Are there custom-fit seals available for open Kallax back panels?
Created on: 26 Dec 2024 14:37
Benbajram
Benbajram
26 Dec 2024 14:37
I have a question about whether there are any custom-fit seals available for the open-back Kallax shelves. Specifically, I am looking for a solution to better seal the open backs against dust and some moisture, as I have noticed that the backs in my unit sometimes fit a bit too loosely and therefore do not provide optimal protection. I am not looking for complete room sealing, but rather a product that fits as precisely as possible and can be easily installed without major modifications.
I have already checked with IKEA and various accessory suppliers for suitable seals, but so far have not found anything that fits well, especially for the Kallax with the open back. If anyone has experience with this or knows manufacturers that offer something like this, I would be very interested. Tips on alternatives that can be cut to size would also be helpful.
Thanks in advance!
blapau
26 Dec 2024 15:51
Regarding precisely fitting seals for open Kallax back panels, I can share from experience that there are hardly any specific products on the market designed exactly for Kallax. The shelves are modular and relatively affordable, so accessories tend to be more universal.
One possible solution is to cut seals yourself from suitable foam rubber or silicone profiles and attach them with double-sided tape. These provide good dust protection and a slightly flexible seal against minor moisture exposure. Advantage: You can tailor the seal very precisely to the back panel dimensions.
Specialized seals pre-formed exactly for Kallax back panels are, to my knowledge, rarely available on the market. This is probably due to demand and manufacturing effort. Therefore, it is worthwhile to take the DIY approach using appropriate sealing materials.
Dilen
27 Dec 2024 09:22
First, I would like to discuss the construction of the Kallax back panels, as understanding these components is fundamental when it comes to fitting precise seals. The back panels are made of thin MDF or hardboard, which are slotted into grooves. The frame construction of the shelving unit remains open, meaning the back panel is often only lightly secured and therefore flexible. This particular design makes it difficult to install a rigid, perfectly fitting seal.
Another factor is that the Kallax shelf is not originally designed as a fully enclosed storage space to protect against moisture or dust. The open back mainly serves aesthetic purposes and accessibility.
For a practical sealing approach, I recommend the following:
1. Material selection: Soft PVC or silicone profiles with self-adhesive backing, available in various widths. Make sure they are UV- and temperature-resistant so the seal remains durable and does not degrade over time.
2. Measuring: Measure the back panel precisely. It can be useful to create a cardboard template to fit the profile exactly.
3. Attachment: Install the profile so that it seals the back panel on all sides without making installation or removal more difficult.
4. Air circulation: Since a complete seal can cause moisture issues, I recommend leaving small air gaps or ensuring slight ventilation.
blapau schrieb:
Eine mögliche Lösung ist es, selbst Dichtungen aus geeigneten Moosgummi- oder Silikonprofilen zuzuschneiden
That sums it up well, as there is currently no reliable source for precise industrial products.
Do you have exact measurements or the type of back panel you plan to install? That way, more specific recommendations could be provided.
Kinbu
27 Dec 2024 11:07
Hello Benbajram,
I think your question is well considered, and I would like to add a small supplement. For Kallax back panels made of thin wood fiberboard, their airtightness is indeed limited. There are no ready-made, precisely fitting seals available, as confirmed by the posts here.
What you can do to improve dust and moisture sealing is a two-component approach:
- First: Attach a thin rubber gasket or self-adhesive sealing strips along the edges of the back panel. These strips are often found in hardware stores under "window seals" or "door edge seals." They can be cut to size flexibly and are inexpensive.
- Second: Apply an additional thin coating layer on the back panel itself, such as a lacquered or laminated surface, to minimize moisture absorption. For example, use a matte film or transparent clear coat.
This way, the back panel becomes more stable, remains lightly sealed, and dust infiltration is significantly reduced.
Dilen schrieb:
Since complete sealing can cause moisture problems, I recommend leaving small air gaps or ensuring slight ventilation.
This is an important point because overly airtight solutions can cause moisture damage over time, especially for furniture in rooms with changing climate conditions.
I hope these tips help you, and feel free to ask if you need more information!
