ᐅ Are there flexible furniture films or edge wraps available for curved corners on KALLAX units?
Created on: 12 Sep 2020 09:23
Z
zeynel61Hello everyone,
I am currently planning to customize my IKEA KALLAX shelf a bit more individually and have therefore been considering using furniture films. My specific question is: Are there curved furniture films designed especially for the rounded corners on the KALLAX?
I know many films work well on flat surfaces, but with the KALLAX corners—which are not sharp-edged but somewhat rounded—I am unsure if there are special films that can be applied without unattractive wrinkles or air bubbles.
Has anyone had experience with films for these corners or knows of alternatives to achieve a clean finish? I would really appreciate any advice or tips, especially regarding brands or methods that have proven effective.
zeynel61 schrieb:
Are there curved furniture films specifically designed for the rounded corners of the KALLAX?Hello, that’s a very specific and good question! I have worked with furniture films myself and know that the areas around the corners are often problematic. Usually, special edge protection films are used, but I can’t say for sure if there are curved films precisely cut to fit KALLAX corners.
I imagine that with some skill and a heat gun, you can shape regular flexible films to fit the corner without creating wrinkles. However, this isn’t always easy, and I understand your wish to use something ready-made.
Have you checked with specialized film manufacturers or IKEA accessory stores? Maybe there are also DIY videos showing how to make the films temporarily flexible? If you try it out, I’d be very interested in your results!
zeynel61 schrieb:
Are there curved furniture films specifically for the rounded corners of the KALLAX?Hi! Furniture films are generally made from PVC or vinyl, and yes, there are so-called “molding films” that are more flexible and better suited to wrapping around curves than rigid films. However, with most standard films, problem areas tend to occur at corners that are not right-angled.
As far as I know, there are no pre-made curved films specifically designed to perfectly cover the rounded edges of the KALLAX. It is usually recommended to use a thermal or hot-air technique to make the film more flexible, then remove excess material with a squeegee and a cutter.
Alternatively, you can cut small matching pieces of film and apply them slightly overlapping at the curves to avoid wrinkles. Thorough surface preparation and patience during application are always important.
I have done this on a different shelf before, and it worked reasonably well, though not perfectly. If you like, I can share some tips on the hot-air technique.
Here are some structured tips on furniture films and especially curved corners for KALLAX:
1. Material selection:
Most common furniture films are flat rather than specially curved. However, there are flexible films made from polyvinyl chloride (PVC) that can be shaped by heating.
2. Preparation:
The corners of the KALLAX are actually slightly rounded, which does not allow for a sharp fold. Therefore, the films should be treated with hot air (hairdryer or heat gun – very carefully!) to make the film more elastic.
3. Application techniques:
- Warm up the film with a hairdryer.
- Smooth it gently with a plastic squeegee.
- Carefully cut off excess film at the corners with a utility knife.
4. Special solutions:
To my knowledge, genuinely curved furniture films precisely cut for KALLAX corners are not commercially available. However, custom-made films can be ordered, although they tend to be quite costly.
5. Alternative:
If the film wrinkles too much, you can cut small narrow strips and stick them overlapping along the curve – this allows for better fit.
I hope this helps! Don’t hesitate to ask if you have questions about any of the steps. This is something you can definitely do with a bit of patience.
2. Preparation:
5. Alternative:
Chendu schrieb:
There are no real curved furniture films for KALLAX corners.I agree with that, but I think the question reveals a fundamental misunderstanding: furniture films are usually flat films that you have to shape yourself. Expecting a pre-shaped, ready-made film for such a specific corner is unrealistic.
Covering shelves by stretching films around corners or curves is standard practice, but it requires practice, practice, practice. Anyone who thinks there is a special adhesive kit for power users is mistaken. This also shows that DIY with furniture films is more for people who are not afraid of making mistakes.
So: better call it what it is and do it yourself, instead of hoping for curved miracle furniture films.
