ᐅ Are there common construction defects associated with the IKEA Brimnes furniture?
Created on: 26 Dec 2021 13:47
ericpeoAre there common construction defects with the IKEA Brimnes? I am interested in whether other users have noticed similar issues during assembly or use. Specifically, I would like to know about aspects such as stability, material quality, and features like drawers or doors. Since this piece of furniture is quite popular, certain weaknesses might occur more frequently and could possibly be avoided by careful assembly. Who has experience with this and can describe it in as much detail as possible? It would be especially helpful to hear about problems that are due to the design rather than assembly errors.
The Brimnes system is fundamentally solidly constructed. However, issues with squeaking noises from the drawers sometimes occur, usually due to low-quality coating on the drawer slides. Occasional readjustment or cleaning of the slides can resolve the problem. Slight warping of the doors has also been observed after extended storage or improper installation – it is important to carefully ensure the screws are tightened correctly.
In general, there are no significant design flaws in the Brimnes that can be attributed to IKEA. Most issues stem from assembly errors or the typical wear and tear of MDF panels, which are not suitable for excessive moisture. It is important not to overtighten screws and to use the provided dowels correctly. The drawer problems mentioned earlier often result from uneven loading or rails that are not installed completely level. For stability, ensure a flat surface underneath and, if necessary, use additional corner brackets.
Giagau schrieb:
Slight warping of the doors has also been observed after prolonged storage or improper installation This matches my own observations. The doors of the Brimnes are made of coated MDF, which can swell when exposed to moisture or poor storage conditions. A common cause of issues is uneven tension from over-tightening screws at individual points. To prevent warping, it is advisable to gradually and evenly tighten all screws during assembly.
Ianlau schrieb:
not suitable for excessive moisture I want to emphasize this: a key construction fault is rather the lack of information from IKEA stating that the furniture is not designed for damp environments. Users nevertheless report using the furniture in bathrooms, which then damages the material.
