ᐅ Are there any smart ideas for using PAX wardrobes as shoe storage?
Created on: 29 Apr 2022 10:17
NONLANDRYN
NONLANDRY29 Apr 2022 10:17Good morning everyone,
I am considering whether there are clever and practical ideas for using the IKEA PAX wardrobe as a shoe cabinet. Specifically, I am looking for solutions that go beyond just adding a simple shelf inside a large wardrobe and instead improve functionality tailored specifically for shoes. For example, how can shelves or compartments be adjusted to optimally accommodate different types of footwear – from athletic shoes to boots and dress shoes? Are there any proven inserts or modifications that can make the existing storage space more efficient and organized?
I am also interested in how to adapt the PAX wardrobe in a way that preserves freshness, such as by incorporating ventilation or using special materials to prevent the shoes from developing odors.
I look forward to your practical tips, experiences, or creative ideas on the topic of “PAX as a shoe cabinet”!
Hello NONLANDRY,
You’ve asked a very interesting question that applies to many people with the same piece of furniture. Basically, the PAX wardrobe is very flexible and can be used quite effectively as a shoe cabinet thanks to its adjustable interior fittings.
A proven method is to install special, shallow drawers with perforated bottoms. These provide good ventilation and allow flat shoes to be stored comfortably. For boots, I recommend using removable boot holders or inserts that support the shaft, so nothing falls over or gets bent.
Additionally, you can fit angled shelves so that shoes are clearly visible from above while saving space at the same time. Ventilation can be achieved through a small perforated panel at the back or by using mesh elements instead of the usual solid back panels.
Last but not least, storage boxes that are compatible with the PAX system can be used for an organized and stackable solution. I hope this helps as a starting point!
I would like to bring some structure to this topic. Optimizing a PAX wardrobe into a functional shoe cabinet can be clearly defined in several steps:
- Planning: First, measure the available height and depth inside the cabinet, as shoes vary in size.
- Shelf design: Flat shelves or angled shelves work well for sneakers and low-cut shoes. For boots, use height-adjustable shelves or extra-wide compartments.
- Use of drawers: Shallow, pull-out drawers made of plexiglass or wire mesh provide quick visibility and ventilation.
- Ventilation: Since standing shoes retain moisture, I recommend drilling air holes in the back panel or using a mesh panel instead of the back panel.
- Lighting: LED strips inside the cabinet improve visibility, especially for dark shoes and deeper cabinets.
Avoid compartments that are too tight, which can damage the shoes.
I have personally converted a PAX wardrobe like this and can confirm that ventilation and individually adjustable shelves make a big difference.
Hello NONLANDRY,
to explicitly answer your question again: Yes, there are smart ideas for using PAX as a shoe cabinet, and these are not limited to simple shelves. Here are a few approaches:
- Using special shoe rack inserts that are ergonomically designed for shoes
- Installing adjustable shelves that can be easily moved in height to accommodate different shoe heights
- Modularity through removable boxes or baskets that can be pulled out as needed
- Adding wheels or drawers to maximize use of the lower areas
However, you should also pay attention to humidity, as you already pointed out. Small ventilation holes or perforated back panels can make a significant improvement.
Transparent drawers are also very popular to keep an overview without having to take everything out.
If you like, I can provide specific dimensions and product recommendations in a follow-up post.
I would like to add to the topic with a brief tutorial on how to convert the PAX wardrobe for shoe storage:
1. Plan the interior layout: Measure the shoes you want to store and note key dimensions (height, depth).
2. Choose materials: Use sturdy but lightweight shelves—extra-flat versions made of metal or wood work well.
3. Install angled shelves: Small battens can be used to mount the shelves at a slight angle so the shoe tips point downward and the shoes stay securely in place.
4. Use drawers: Transparent pull-outs are ideal for small shoes like sneakers or ballet flats—this makes it easier to find them.
5. Ensure ventilation: Remove the back panel or replace it with breathable material. Additionally, you can install a small ventilation grille.
6. Utilize the inside of the doors: Hang slim hooks there for flip-flops or narrow shoe accessories.
Common mistakes to avoid: incorrect shelf depth measurements, lack of ventilation, and using hard surfaces that can deform the shoes.
I hope this helps with your project!
